Any Dents in Macon/Warner Robins and Suspension Question.
I wonder any you guys out there have done anything with your I beam suspension? I think my front rake is due to sagging springs because when I jacked the front to replace a tire I noticed it sat higher for a couple hours before going down to its usual height.
You can't do anything with the beams themselves. You can change bushings , springs, king pins, shocks. The beams themselves can't be bent or heated. Same for radius rods.
I do know where there is a junkyard that has about 5 acres of Ford trucks. See my post on" I found a honey hole" Just checked Oriley's had everything except the beams and radius rods.
on
I would think that new springs would raise it back up and be enough for the engine upgrade, I personally dont think there would be that big different in engine weights.
Bronco graveyard as they have stock height up to 6 inch lift: $90 to $189 depending on how much lift you want. Coil Springs-Broncograveyard.com
Lower spring pad is $30 bucks each: 1976-1977 Coil Spring Lower Pad-Broncograveyard.com
I do not seen any upper spring pads, never had mine apart so I can't tell you if they have a lower.
avellaneda13
09-21-2018 05:57 AM
turret_plug
11-07-2007 05:56 PM
