LOWERING SPRINGS
Old Sep 19, 2018 | 09:18 PM
avellaneda13's Avatar
avellaneda13
LOWERING SPRINGS
So o jave a lowered 86 f150 2x4 with djm dream beams in front im looking for more drop with springs, do they have camber bushing for lowered vechiles.
Old Sep 19, 2018 | 09:48 PM
avellaneda13
Picture picture
Old Sep 20, 2018 | 04:58 PM
Franklin2's Avatar
Franklin2
They have camber bushings, that is standard parts to align these trucks. The problem is they only have so much adjustment to them. I know when you raise one of these trucks the bushings only allow you to lift it 1.5 inches before they cannot bring the alignment back in. I am going to assume it would be the same from dropping it down, I would not go over 1.5 inches.
Old Sep 20, 2018 | 05:40 PM
avellaneda13
are the same bushing for raising the vechile as for lowering
Old Sep 21, 2018 | 05:57 AM
Franklin2's Avatar
Franklin2
Yes. the bushing is just a eccentric where the upper balljoint mounts. Instead of having the hole for the upper balljoint machined into the suspension arm for a direct fit, the upper hole is oversized and the eccentric bushing fits in the hole and then the upper balljoint fits in the bushing. The alignment guy loosens all this up when he is aligning it, and spins the bushing around till it's correct. The programming in the alignment machine will usually tell him what degree of bushing he needs to install, they have different amounts of eccentricity. All this work is also why these trucks cost more to get aligned. A lot of poor shops won't even mess with this, and charge you just to set the toe.
muth_33
Mar 31, 2016 10:36 AM
rm.lydon08
May 15, 2012 09:53 AM
ItsAFord55
20
Aug 2, 2011 10:20 PM
xc4jokestomper
13
May 30, 2011 04:43 AM
turret_plug
Nov 7, 2007 05:56 PM
