Front end Issues Pt II
Old Nov 16, 2015 | 10:02 AM
DocsExcursion's Avatar
DocsExcursion
So I gave the local shop a run, and they replaced the inner oil seals, and the upper and lower ball joints on the passenger side.
I have already replaced, steering damper, and left/right sway bar links.
I now I see grease on the driver side lower ball joint, the actual boot looks worn, what do you guys think is needed??
Should they re-inspect the inner oil seals? or just replace the ball joints on the drivers side?? Mind you the noises I used to hear on the passengers side I now hear on the drivers side SMH
Old Nov 16, 2015 | 10:57 AM
Krazee Matt's Avatar
Krazee Matt
Veteran: Navy
Ball joints are typically done as a full set, not side by side.... If you're hearing the same noises, then yes - replace the driver side.
Old Nov 16, 2015 | 11:35 AM
DocsExcursion
I figured that both should be changed at the same time.
The fluid around the lower ball joint on the driver side?? what can that be coming from??
Old Nov 16, 2015 | 12:29 PM
pirate4x4_camo's Avatar
pirate4x4_camo
FTE Remembers
Call me captain obvious but I will go ahead and speculate it is from the lower ball joint. What makes you think it is from something other then the ball joint ?
Old Nov 16, 2015 | 01:34 PM
DocsExcursion
I was told the inner seals were leaking, so i fixed it...then i check and the seal is so i did research and decided to ask you guys.
paid the price for a good deal on this EX..
BUT im putting the work in for this machine to be the best!!
Old Nov 16, 2015 | 01:45 PM
pirate4x4_camo
FTE Remembers
Bummer, Replacing an inner axle seal is a lot of work as it is located inside the axle housing next to ring gear carrier. It requires removing the axles and ring gear carrier to replace it. The tell tale sign a inner axle seal has failed will be 90 weight gear oil leaking down your C yoke. If it has been replaced but is still leaking it was either damaged when the axles were reinstalled of there is a blemish on the axle where the seal rides and it is allowing gear oil to leak past the seal.
Old Nov 16, 2015 | 03:57 PM
DocsExcursion
I'm hoping it's just the lower ball joint leaking. I don't see any oil leaks anywhere else now, just that lower ball joint on the drivers side that hasn't been replaced yet.
Old Nov 16, 2015 | 04:39 PM
afmedic's Avatar
afmedic
When you hear hoof beats think horses not zebras. I agree with the advice above and if there is no fluid leaking from the c yoke I would say ball joint is due to be replaced.
Old Nov 16, 2015 | 05:29 PM
WE3ZS's Avatar
WE3ZS
If your inner oil seals were leaking (pretty rare), and have now been replaced there could be some residual oil laying in the axle tubes that is still finding its way out at the knuckle. Maybe the shop that did the seals didn't do a perfect job of cleaning out the tubes.
If it looks like a ball joint is puking out grease, it is time for it to go.
Old Nov 17, 2015 | 07:37 AM
DocsExcursion
i love this site!!!
thanks everyone!!
Old Nov 17, 2015 | 09:16 AM
Toreador_Diesel's Avatar
Toreador_Diesel
FTE Leadership Emeritus
When you do ball joints on these trucks, you never know what you're going to find
Ain't that right Matt?
Old Nov 17, 2015 | 11:26 AM
Krazee Matt
Veteran: Navy
F ball joints and everything remotely associated with them.
Old Nov 17, 2015 | 12:54 PM
DocsExcursion
Checked and it's only at the Ball Joint. I will replace them in the morning, and my rotors and pads, and get the Alignment re-done.
Should be cool after that, it's been a ruff few weeks.
Old Nov 17, 2015 | 01:34 PM
Toreador_Diesel
Wicked Endings
Aug 22, 2010 06:23 AM
Ryan T
1997 - 2003 F150
Apr 25, 2008 10:27 PM
mxfam4x4
Oct 27, 2006 06:40 PM
robbiecox6
1983 - 2012 Ranger & B-Series
Apr 10, 2005 06:11 PM
MitchPeters
Jul 7, 2004 09:45 AM
