Lower Ball Joint
Old Apr 10, 2005 | 04:24 PM
robbiecox6's Avatar
robbiecox6
Lower Ball Joint
How can you tell if your lower ball joint is going bad?
Old Apr 10, 2005 | 06:11 PM
el conquistador's Avatar
el conquistador
jack the front end up, put a pry bar under the suspect wheel and pry up with someone watching the ball joint. a bad ball joint will be evident by a lot of movement.
