418 build
Old Nov 16, 2015 | 12:23 AM
rivermobster's Avatar
rivermobster
Originally Posted by Tedster9
Are you building a drag racer that will be at WOT all the time, every time? OR, like you mentioned, a daily driver?
Because, if you build the former but try to use it as a daily driver it won't ever idle smooth or run well, except at WOT. Too big of a carb is a classic error.
Just by way of illustration as an experiment, plug in your RPM at a regular highway cruise speed of say, 65 mph into the CFM tables. Hint: It won't be 750 CFM, not even close.
Just something to think about. Now I'm not against big carbs, it's just that for the best performance it's actually better to error on the side of too small, not too big. Especially on a daily driver.
This ^^^
Old Nov 16, 2015 | 12:48 AM
deckertd's Avatar
deckertd
Originally Posted by rivermobster
Nope. Mixture and flow are independent of each other. If the air if flowing quickly though the carb, the carb works well. It's efficient. It does what it's designed to do.
[/url]
Holy COW Tonto.. I darned near had a heart attack on the carb $$$ Is there GOLD in them there parts?
Seriously though, that looks like a darn good compromise for what I'll be running. Huge thank you for the advice & link.
Every ones input has already saved me from some MAJOR possible mistakes for the build. This group is A #1..
Dan
Old Jul 22, 2016 | 01:47 PM
deckertd's Avatar
deckertd
418 Dyno Run
Got the dyno run completed. Couple of minor leaks around valve covers. Wound up going with 12 degrees @ idle, rev limiter off, 20 degree max advance arms with medium rate springs on the Pertronix dizzy. Only tested to 5k rpm cause I doubt I'll ever be running it there. Running a 750 cfm Edelbrock 1411. It's ok for street/daily driving but that's about it.
Power was still climbing on 2nd log run but starving on the A/F ratio with timing @ 6 degrees base. Plus the motor wouldn't idle.
Logs are from 3 runs from 1st to last. Left the motor per the 3rd run.
FWIW, a 1.5"x 3" patch of ceramic coating on the header (#6 cylinder) flaked off after the 2nd pull. Company said they'd recoat it but attributed the issue to an overhot cylinder. On a carb engine?
1 flex exhaust pipe blew apart during one of the runs and scared the living sh** out of me. I thought the motor blew up Kinda like a 12ga going off about a foot from yer head...
Dan
Old Jul 25, 2016 | 02:31 PM
abyars111's Avatar
abyars111
That torque number around 3000 makes me grin. That's what you'll love on the street in a daily driver.
Old Jul 25, 2016 | 10:49 PM
deckertd's Avatar
deckertd
Looks like a sweet spot for a 'Flying Brick'?
Now I just need a Dana 60 3:54/3:73 rearend change to get away from the Dana 60 4:10 in it.
I might wanna go more than 100 miles from home on less than 40 gals. of fuel. Now where's that darn rpm calculator......
Dan
Amtek
38
Dec 8, 2011 05:10 PM
TheWarWagon'75
26
May 11, 2009 05:36 AM
RapidRuss
25
May 2, 2004 06:42 AM
pashtrd
16
Feb 18, 2003 09:20 PM
bigblue
13
Jun 5, 2002 02:19 PM
