I have a 96 f250 7.3 everything works but sometimes the window and all the buttons stop working on driver side and passenger but just a bit ago it just stopped again and it's taking longer then usual to work again. When I get good light tomorrow I'm gonna take the door panel off any ideas on what it could be. I'm thinking it could be a fuze
Thanks an advance
Sounds like a shorted wire(or broken wire) where they pass from the cab into the door.
NOT a fuse or it would pop and not work again until you replaced it. The windows use a circuit breaker that resets itself
