STEERING WHEEL WOBBLE!!!
Old Nov 11, 2015 | 09:47 AM
STROKN_n_SMOKN's Avatar
STROKN_n_SMOKN
94 f350 7.3 turbo vin f 5 speed manual. So the steering wheel wobbles up and down like i'm holding the tilt wheel lever, truck has no air bag, does have tilt wheel, and is a stick. What i'm needing is part numbers for bearings I need, It's only the steering wheel not the column. I will include the diagram my ford dealership just emailed me. Thank you in advance for any info.
Old Nov 11, 2015 | 05:39 PM
tjc transport's Avatar
tjc transport
i ain't rite
not sure on the 92 and newer columns, but on the 91 and older tilt columns the tilt assembly is held in by 3 bolts and clamps. over time the bolts loosen up or break, and the wheel flops all over t he place.
Old Nov 11, 2015 | 06:32 PM
z31freakify's Avatar
z31freakify
Check the tension spring might of fallen off or broken
Old Nov 11, 2015 | 06:53 PM
STROKN_n_SMOKN
Oh ok, and if it is the bearings is just part #13318, 3c610, 3520, 3518, 3L539, 3517,and 3524? And I appreciate the info.
Old Nov 11, 2015 | 07:59 PM
STROKN_n_SMOKN
Will do man, thank you. I'm still trying to figure out how to get the plastic cover off the 4x4 lever... When I move it, all the parts under the truck twist and move around but barely shifts.
Old Nov 12, 2015 | 01:09 PM
tlapham's Avatar
tlapham
I did this on my truck recently. my wife has a hard time getting in. STOP USING THE STEERING WHEEL AS A HANDLE TO GET IN THE TRUCK!!!
PinkyRingz
Jan 4, 2020 12:42 PM
herdfan75
Aug 7, 2017 02:51 PM
manger
Oct 11, 2008 10:31 PM
Vinford
43
Jan 6, 2005 12:26 AM
sethro
Mar 18, 2002 09:09 PM
