Help! which 460 distributor
Old Aug 5, 2003 | 09:05 PM
jrhotrod's Avatar
jrhotrod
What kind of recommendations can you guys make on a 460 distributor for an old 78.I have looked at the ACCEL dis. because of the purpose of not having to buy a ign. box to go with it. But tell me what you guys think. this is going on a moderate built 460 not a race motor or anything.Thanks
Old Aug 8, 2003 | 12:53 AM
Hired Gun's Avatar
Hired Gun
A Dura Spark set up is tough to beat.
Old Aug 8, 2003 | 02:27 PM
84F-250HD460's Avatar
84F-250HD460
i would use an MDS pro ford dist. with the MDS6 off road ignition works petty good
Old Aug 9, 2003 | 09:30 AM
ClydeSDale's Avatar
ClydeSDale
When I first got Clyde (1996, 38,000 actual) the distributor was literally literally frozen in place. Ruined the OEM trying to remove it ... always use anti-sieze! ... and had to replace it.
I looked and asked around. I was told by people who had a lot of experience working on and racing 460's that I could spend my money in lots better ways than to replace the OEM with aftermarket.
I've learned since then that rebuilts are infamous for having springs and weights mismatched to the use of the engine. Ford put 460's into lots of vehicles, from TBirds to Motorhome chassis, and the rebuilt you buy at NAPA could have parts from any or all of them. Even a new one may not be perfectly matched to your particular use.
I had my rebuilt set up and recurved by an ignition shop. My distributor is now perfectly matched to my driveline, my driving style and pulling my RV ... Clyde's primary use and purpose.
It was also cheaper
Old Aug 9, 2003 | 10:18 AM
FordBoypete's Avatar
FordBoypete
I do what Clyde S Dale above does.
I use an OEM distribuitor (in good shape - not loose or sloppy) & re-curve advance to match my cam. I use Blue stripe FoMoCo Module w/ "crisp" fresh coils.
I've been known to "dance" down local 1/4 mile a time or 2 w/ a 460 powered 66 F-100. I'm in mid 12 sec et with OEM set up.
I do swap cap & rotor to an older non breakerless set up & set of magetic supression plug wires when I race it.
I also have a heavy F250 Supercab Short bed trailer special w/460. I run OEM set up in it. Again, a Bule Stripe module on it. It also has been set up to match curve of RV Cam engine runs. I pull 18' tag trailer. I've grossed over 17K lbs often pulling a farm tractor weighing 10,500lbs.
I have had zero problems with either distribuitor. F250 has well over 180, 000 miles & 10 years on it. 66 F100 is a few years old & not much milage. Both work fine & can be repaired on the road with OEM parts if they ever do, fail or give me problems. FBp
Ghostka78
May 1, 2013 09:24 PM
crazyeddie
Electrical Systems/Wiring
Dec 6, 2009 09:56 PM
360 Sport Custom
28
Nov 4, 2006 11:11 AM
f100guy
Dec 2, 2003 02:50 PM
