TRANSMISSION WON'T UPSHIFT !
Old Nov 13, 2015 | 11:15 PM
Dr. Johnson's Avatar
Dr. Johnson
Well guys now I'm stumped, new modulator, new vacuum line, vacuum at the modulator and new neutral safety and it still doesn't shift automatically. What now?
Old Nov 13, 2015 | 11:17 PM
Dr. Johnson
I should add that the vacuum pull seems weak at the modulator, and didn't change the idle when I unhooked it... Line looks good and has new rubber on the modulator end.. Confused
Old Nov 13, 2015 | 11:30 PM
MOOSE_MACHINE's Avatar
MOOSE_MACHINE
Check the kickdown rod. I don't know where it is or how it works on a psd but make sure it's moving freely. Vacuum shouldn't effect idle speed on a diesel.
Old Nov 14, 2015 | 07:00 AM
tjc transport's Avatar
tjc transport
i ain't rite
also check what controls vacuum signal. i never messed with an PSD /C6 combo so do not know if they use a VRV or not.
but i will second the check downshift linkage comment also. i had a 79 F350 4X4 given to me 20 years ago to use for parts because "the trans was blown"
he lent the truck out and it came back with a no upshift condition.
i loaded it on the trailer and brought it home. once here i took it for a ride to see what was wrong.
saw it would not shift out of first and pulled over, popped the hood, and smacked the kickdown after noticing it was stuck in pass position.
the person that borrowed it mashed the throttle and jammed the kickdown linkage in pass. once i got it unstuck it worked perfectly.
i have since put over 100,000 miles on that truck
Old Nov 14, 2015 | 08:13 AM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
A stuck governor is about the only thing left that can do this. It was always either the modulator or the governor. I always check the modulator first, both because it is much easier, and it causes many more problems than the governor.
Was the pin that the modulator pushes on inside the trans in place? I've seen the pin get lost and then it doesn't matter what the modulator does it won't make the trans shift.
Old Nov 14, 2015 | 11:30 AM
tjc transport
i ain't rite
forgot all about the pin for the modulator. Mark is correct, without that the trans will not shift.
Old Nov 14, 2015 | 12:03 PM
CampSpringsJohn's Avatar
CampSpringsJohn
Learn something new every day. Never knew a C-6 was available behind the 7.3psd. Why would someone want that option I wonder.
Old Nov 14, 2015 | 01:05 PM
tjc transport
i ain't rite
because they did not trust the overdrive trans.
the C-6 was available as an option on all engines until 1997.
i ran across quite a few C6 trans trucks while i was buying at auction with all the different engines available.
Old Nov 14, 2015 | 02:31 PM
CampSpringsJohn
My F-SuperDuty had 4:88 gears in it. I'd hate to see what that motor would have had to turn to go 70mph on the interstate with a C-6!
Old Nov 14, 2015 | 03:43 PM
tjc transport
i ain't rite
it was not that bad because the tires were larger to compensate for the lower gears.
it would be the same as driving in 4th gear instead of 5th
Old Nov 14, 2015 | 06:23 PM
Dr. Johnson
Problem solved
This takes us back to the keep it simple stupid philosophy... I should've checked the basics EXTENSIVELY first! But since the symptoms were far from familiar I started looking too deep too soon. It was the vacuum source from the start... Someone had messed with the vacuum connection when the modulator failed. Double check your vacuum with a GAUGE! . Thanks for all the input!
Old Nov 15, 2015 | 07:37 AM
tjc transport
i ain't rite
glad it was an easy fix.
Old Nov 16, 2015 | 10:28 PM
  #28
Brettboat's Avatar
Brettboat
A VSS code will cause stuff like this to happen. IT won't throw a flash code but will make your PCM hate you until you clear it out or it clears itself out. Done enough 20-25 PSI boosted launches to know all about that code. Do my launch, plug in my creader, clear out all the codes in threw, turn the truck off, restart... Everything is as it was before.
Old Nov 16, 2015 | 11:00 PM
  #29
madpogue's Avatar
madpogue
^^^^^ It won't with a C6....
fordranger94
1983 - 2012 Ranger & B-Series
Nov 15, 2018 06:13 AM
Kayebaehr
Aug 16, 2017 03:17 PM
Walwal44
Feb 2, 2015 05:12 AM
Ragzz
Apr 21, 2014 07:03 AM
infoguy
Jul 11, 2004 10:26 PM
