1978 - 1996 Big Bronco
Confused..... Need help!!!
Old Feb 24, 2004 | 11:07 AM
frankle's Avatar
frankle
Was out and about this morning, had to drop a package off at the local UPS Store. Left the motor running, when I came back out smoke/steam was coming out of the A/C ducts. Heater or defrost was not on.
Can anyone shed some light on this occurance.
I thought that maybe the heater core could possibly be clogged, but the heater works just fine. I don't have defrost, but I do have good heat.
Any help would be appreciated.
Thanks, Frank...
Old Feb 24, 2004 | 11:35 AM
treehugger36's Avatar
treehugger36
that still sounds like what mine was doing when my heater core went out. Heat would work... but it wouldn't clear the windows, in fact it usually made them worse. And it would smoke out of the vents.
You might take out your glove box and check your H-core. It aint hard. Might save you some trouble.
my $0.02
McNabb
Old Feb 24, 2004 | 11:44 AM
frankle's Avatar
frankle
Thanks Tree,
Will check it out.
Frank...
Old Feb 24, 2004 | 12:51 PM
BillyBob69's Avatar
BillyBob69
What Tree said. that is all the signs of a bad heater core. nice thing is...at least when mine went out...cost only $12 and about 30 minutes of work.
Old Feb 24, 2004 | 01:28 PM
The Tree's Avatar
The Tree
Definitely the heater core, although this could take some time depending on what you have. If you have a 78 or 79 then you're in trouble. The rest are a breeze.
Old Feb 24, 2004 | 01:40 PM
Destroyer's Avatar
Destroyer
I have a 79 and i just changed my 2 months ago, I had to take out all the vents but it wasent that bad and i got to clean them while thay were out, and there was alot of crap in there, so it worked out for the beter.
Old Feb 24, 2004 | 02:00 PM
BillyBob69's Avatar
BillyBob69
Its always nice to get things cleaned up when you have half your dash taken apart....just sucks ya gotta do that much for just the heater core.
Old Feb 24, 2004 | 11:32 PM
frankle's Avatar
frankle
Thanks everyone for the input. Will check it out this weekend. Won't get a chance till then. Bronco is an '85 XLT.
Thanks again, Frank...
Old Feb 25, 2004 | 06:53 PM
horton-racing's Avatar
horton-racing
`85 is a piece of cake. Definitely sounds like the heater core. No water/anti-freeze mixture on the passenger side floorboard/carpet? As Billy Bob said, only about 30 minutes work. Check and make sure your duct work is clean while you are in there. You`d be surprised at what all can make its way from your dashboard to your heater - A/C doors.
