Should I replace my muffler
Old Nov 8, 2015 | 05:16 PM
scottm1's Avatar
scottm1
My 02 7.3 F-250 has a muffler that needs replaced. Should I replace it with another muffler, or should I get the pipe to go in place of the muffler and do away with the muffler? The exhaust is currently all stock. Those of you that have deleted the muffler, how muck louder is your truck after doing this?
Old Nov 8, 2015 | 05:41 PM
sudsmcduff's Avatar
sudsmcduff
I have 5" straight pipe. Much louder and drone after I removed the muffler.
Old Nov 8, 2015 | 07:47 PM
scottddove's Avatar
scottddove
I have the muffler delete brand new from riff raff that I never got to put on my truck. (Totaled it). Pm me if your interested.
Old Nov 8, 2015 | 08:27 PM
Nicmike's Avatar
Nicmike
Veteran/Sheepdog
I would go with an FTE resonator in place of the muffler. I had one on my 5" exhaust and it made a very cool jet-turbine sound instead of the big-block-chop a muffler gives.
http://www.ftediesel.com/store/pc/vi...4&idcategory=7
Old Nov 9, 2015 | 08:44 AM
CarterKraft's Avatar
CarterKraft
Walker 21470 for me. Not exactly a bolt in deal but a muffler shop can get in pretty easily.
Same V8 diesel sound with more turbo whistle.
Old Nov 9, 2015 | 08:46 AM
glockholiday's Avatar
glockholiday
I replaced my muffler with a piece of pipe over a year ago. If I did it again I'd put the FTE 4" Resonator in it like in the above link from Mike. It's on my to do list.
Old Nov 9, 2015 | 11:49 AM
scottm1's Avatar
scottm1
Is the FTE resonator a direct drop in replacement for the muffler, or does it require addtl piping on the ends to fit?
Old Nov 9, 2015 | 11:52 AM
Nicmike's Avatar
Nicmike
Veteran/Sheepdog
Direct drop in. The one I had was flared on the ends. Listing says " 4" ID Inlet & Outlet"
Old Nov 9, 2015 | 01:38 PM
glockholiday
I think it would need a little work to install since stock is 3.5". Nothing a muffler shop couldn't handle.
My stock muffler is laying next to my garage I'll check the length tonight.
Old Nov 9, 2015 | 03:00 PM
Nicmike's Avatar
Nicmike
Veteran/Sheepdog
Yep, he will need a couple of adapters from 3.5" to 4".
Old Nov 9, 2015 | 05:27 PM
Sous's Avatar
Sous
FTE Leadership Emeritus
FTE Emeritus
Going to need something like this on each side of the resonator.
Summit Racing® Exhaust Pipe Adapters SUM-652257 - Free Shipping on Orders Over $99 at Summit Racing
Old Nov 11, 2015 | 09:16 AM
glockholiday
My stock muffler body is 20" but because of how the hangers are welded to it I cut a total of 24" of of the stock exhaust to remove the muffler.
mikec91
May 16, 2013 10:03 PM
06silvercrew
Dec 29, 2010 09:23 PM
whitewhale
Jul 15, 2010 11:04 AM
merlins'92f250d
Jan 23, 2006 11:18 PM
