Sunroof leak fix! $10
Fixed my leaky sunroof with 6' of clear 3/8 ID clear vynl tubing from lowes and a tube of caulk. Used the caulk to seal up around the body plug i removed where my finger is pointing. None of the tubing is crushed and it works great! Hopefully this will help anyone else who has a bad hose.
Mine was kinked in two places inside the a pillar. I pulled the entire hose out tried to feed the new one in and would have ended up with the same problem. So i just re routed it. All the others seem to drain fine so i assume this was just a messup at the factory.
Removed my glass after a rain fail and water was sitting waiting to drain, overflow had already leaked down a pillars. With the sunroof glass removed I then removed dead leaves and dirt debris from trough. Used speaker wire to fish through 2 front drains, voila. Water poured out underneath my truck. Also when I was up there, I looked at the seal around the glass, it was badly aligned. I manipulated the seal reinstalled the glass with a torx bit
So happy. Waiting for the next rainfall to see if I get wet carpets
Domestic Violence
06-14-2007 03:56 PM
MIMI727
1997-2006 Expedition & Navigator
07-29-2005 07:29 AM
