EGR-pro and con?
Old Nov 7, 2015 | 01:12 AM
SixPoppin''s Avatar
SixPoppin'
EGR-pro and con?
I have read mention that the EGR actually can help fuel economy. It also would seem to help warm up the engine in cold weather. On the flip side of the coin, EGR is not known for boosting power output due to higher charge temps and introducing a non volatile mixture to the combustion chambers. Does anyone have any interesting insights concerning the advantages and disadvantages of EGR use? Particularly with a non computerized vehicle.
Old Nov 7, 2015 | 08:42 PM
The Frenchtown Flyer's Avatar
If it came factory supplied I would use it. But I don't go out of my way to use it on my hot rods. The factory fuel and spark curves are optimized for EGR, using the factory intake and exhaust systems.
EGR is not functioning when the engine is running at WOT
Old Nov 7, 2015 | 08:45 PM
Galendor's Avatar
Galendor
Hi there!
Pros of EGR:
1) Allows one to run more timing advance without pinging
2) Makes engine run a bit cooler
3) Is compliant with Federal law
4) Reduces NOx emissions/less pollution
Cons of EGR:
1) If the valve fails in closed position, it doesn't work and you might not even know it failed
2) If the valve fails in an open position, engine idle quality is badly affected
3) Function requires proper regulation so valve opens only when engine rpms are relatively high
4) It takes up a small amount of space near the engine
Old Nov 8, 2015 | 01:04 PM
ZarK-eh's Avatar
ZarK-eh
When are they supposed to open and close?
I put a DIY efi on mine, and want to hook up the EGR but don't know when it should be open or closed...
And for that matter, I'm going to be adding a Catalytic Converter to this truck of mine which started without one... Trying to go for a Enviro-green truck
Old Nov 8, 2015 | 06:14 PM
An EGR valve is load-modulated, i.e. exhaust backpressure modulated. You have to have sufficient load on the engine to make it function. The higher the load, the more EGR gas gets delivered. In addition, it does not function at idle and it also cuts out at wide open throttle. Various methods are used to control it depending on the year, carbed or EFI.
David Unruh
Mar 21, 2025 11:09 AM
stangr8cr
6.7L Power Stroke Diesel
Feb 22, 2014 11:24 AM
Fluid Power
May 30, 2007 12:32 AM
cooky
Dec 1, 2005 12:00 AM
Steve390
17
Mar 12, 2003 03:12 PM
