1994 Ranger XLT A4LD Auto Trans Issue
Hi everyone, I have a 1994 4x2 shortbed standard cab Ranger XLT. It has the 4.0 OHV engine, A4LD Automatic transmission, and 195,000 miles.
Under average driving conditions, it operates fine. It shifts up through the gears much like it always has, although the shifts may not be quite as firm as they used to be.
If I'm at cruising speed and step harder on the accelerator, it downshifts, RPMs increase, and it upshifts rather poorly, & then I feel a thump, (maybe the torque converter locking up when it shouldn't be?), and I'm in the higher gear. This seems to happen when it upshifts from 3rd to 4th gears for sure, maybe from 2nd to 3rd, but I'm not sure. Again, it only seems to happen when I attempt to speed up from cruising speed, not from a stand-still.
The transmission fluid and filter have been changed at regular intervals, and the truck has never been abused. The fluid is red in color, doesn't smell burnt, and the level is correct. I don't want to get rid of this truck if I can avoid it. It has been super-reliable and mostly trouble-free for the 16 years I've owned it.
What do you think might be wrong with it? Thanks to anyone who might have a tip to help me...
I'm posting this in the Ranger & B-Series threads, too. Should I remove it from there?
This thread was moved to the Ranger & B-Series Forum. It's under "1994 A4LD Auto Transmission: Help, Please."
https://www.ford-trucks.com/forums/1...lp-please.html
daniel5625
1983 - 2012 Ranger & B-Series
01-21-2011 05:25 PM
tmryan362
04-23-2005 08:16 PM
