Modular V10 (6.8l)
Cat Delete
Old Nov 6, 2015 | 04:04 PM
the cleaner's Avatar
the cleaner
Cat Delete
Is there any advantage to doing a Cat Delete on the V10? Do U replace the cats with a free flow cat or just fill in with pipe?
Old Nov 6, 2015 | 04:26 PM
85e150's Avatar
85e150
If you have a sensor after the cat, you have to get a tune or chip to fool the computer into seeing the right mix after the cat. Without doing that, it will eventually run in a limp or cold mode or worse.
As for power, unless your cat is clogged, you will never feel the difference, as any gain will be a WOT at max rpm or close to it.
Old Nov 6, 2015 | 04:37 PM
the cleaner
Ok Thanks, I was just wondering if there was any advantage.
Old Nov 7, 2015 | 10:54 PM
jonmorgan's Avatar
jonmorgan
Funny that you would ask actually. I just put my cats back on after them being off for a year. And I can tell you that you will hate it. One one mine was plugged so I cut them both out. The drone was so damn loud it was crazy. It runs rich constantly to the point that it makes the truck black next to the exhaust tip. Also consuming fuel way more than normal. I can tell you that this week after putting them back in the drone is mostly gone, I got a full 2mpg better and the power is back in my truck. Hold a gear on hills much better. I wish I'd never have done that. Just one mans opinion but first had experience.
Old Nov 15, 2015 | 09:54 AM
harley4jcs's Avatar
harley4jcs
You put a clogged cat back on ?????
muddfrog
Modular V10 (6.8l)
Dec 16, 2008 06:10 PM
joker944
Exhaust Systems
Oct 29, 2007 12:33 AM
c00nhunterjoe
22
Aug 9, 2007 02:11 PM
Prplmnsterf150
Exhaust Systems
Mar 3, 2005 08:26 PM
ACRKENTUCKY
Exhaust Systems
Mar 14, 2003 12:48 PM
