Ignition Bezel - 1949
Old Nov 6, 2015 | 10:14 AM
johnfin1's Avatar
johnfin1
How does the ignition key bezel come off?
Old Nov 7, 2015 | 08:46 PM
3twinridges's Avatar
3twinridges
I would use a rag behind and in front of the edge of a flathead screwdriver to protect finishes while using the blade to pry it off the switch. The ignition has a type of "receiver" for a spring type circular clip on the back of the bezel that you cannot see by looking at it installed. Does that make sense? Maybe two screwdrivers. One to hold what you have while you go for more leverage. Be gentle, that clip may be rusted and weak / and break!
Jonathan
Old Nov 7, 2015 | 09:07 PM
Gertie-The '49 F2's Avatar
Gertie-The '49 F2
Jonathan is correct, in that they just pop off by prying under the edge of the bezel. As was said, be careful to not scratch the paint finish.
Unless the inside of your cab looks like a rusted-out Michigan inner fender, it should come off pretty easily.
Also, there are some dandy tools that cost little for such jobs as trim and bezel removal. Some are steel forked types with nice beveled and rounded edges, others are made from a tough nylon.
48ATOY
Nov 3, 2004 05:58 PM
jethro1
Apr 8, 2004 06:30 AM
kwt
Feb 6, 2004 10:17 AM
41Clay
Oct 24, 2002 05:20 PM
41Clay
Oct 17, 2002 11:00 PM
