Hook Latch Spring Help
Old Nov 6, 2015 | 08:29 AM
jonmammenga's Avatar
jonmammenga
Hello,
Does anyone have any suggestions on how to keep the coil spring that is attached to the underside of the hood near the latch from sliding off the landing pad when closing the hood? I have bent the spring back straight and messed around with alignment and so forth but can't seem to keep it from sliding off.
I have had 7 other F150's from 73-79 that I have never had this problem with.
Suggestions are appreciated!
Old Nov 6, 2015 | 12:35 PM
77&79F250's Avatar
77&79F250
Moderator & parts slinger
Get a new spring, or put a very small headed carriage bolt in the core support. With the rounded head on the top, maybe it will hold the spring centered. Make sense?
Old Nov 6, 2015 | 03:48 PM
jonmammenga
Get a new spring, or put a very small headed carriage bolt in the core support. With the rounded head on the top, maybe it will hole the spring centered. Make sense?
I took another spring from a different hood I had that worked just fine and it did the same thing again. I will give the carriage bolt idea a shot if I can get something in there.
Old Nov 6, 2015 | 05:31 PM
77&79F250's Avatar
77&79F250
Any chance the contact area is bent? Maybe paint the contact area with anti skid paint or but some self adhesive none skid material there?
JohnS49
19
Jan 17, 2012 09:15 AM
pademc
Feb 19, 2004 03:41 PM
jambroson
Nov 23, 2003 06:45 PM
