How do I get this timing chain off?
Old Nov 6, 2015 | 05:32 PM
Cbad285's Avatar
Cbad285
I left it at this point because I'm not sure how to take it off.
Any pointers guys?
351C
Old Nov 6, 2015 | 05:41 PM
bigdan1979f-250's Avatar
bigdan1979f-250
Yeah, both the top and bottom sprockets come off with the chain at the same time. You might have to gently pry around them until they start to work loose.
Old Nov 6, 2015 | 05:43 PM
tabascom16's Avatar
tabascom16
You need to pull the gear off the cam shaft. You will probably need a bearing puller for the job.
When you put a new one on you do it in reverse order...the chain has to be looped around the large timing gear before it goes onto the cam shaft.
Xwarrior86
Oct 8, 2015 11:34 AM
albung
Feb 24, 2008 05:22 PM
qman
Jul 28, 2005 12:42 PM
SPROCKET
Nov 10, 2003 01:29 PM
Elk6969
1978 - 1996 Big Bronco
Mar 29, 2002 07:09 PM
