Drivability concerns
Old Nov 6, 2015 | 07:05 PM
bigfordandjeep's Avatar
bigfordandjeep
Just started x. At idle map is 14.4 psi and ebp is 15.5 psi
Old Nov 6, 2015 | 07:23 PM
jhl3's Avatar
jhl3
OK. What are they at Key On Engine Off? Can you log data during a WOT run?
Old Nov 6, 2015 | 07:25 PM
bigfordandjeep
They are the same KOEO
Old Nov 6, 2015 | 07:26 PM
bigfordandjeep
5 o'clock traffic right now. Hard to get wot for more than a second or two
Old Nov 6, 2015 | 07:41 PM
jhl3's Avatar
jhl3
So, for clarification, your EBP does not decrease with the engine not running while the key is turned on?
Old Nov 6, 2015 | 07:51 PM
bigfordandjeep
No the numbers were the same.
Old Nov 6, 2015 | 08:00 PM
bigfordandjeep
I'm going to pull the edge tomorrow and install the ts chip. See what that does.
Old Nov 6, 2015 | 08:07 PM
jhl3's Avatar
jhl3
OK. However, at KOEO, the two reading should be within .1-.2 of each other. It might be worth your while to get a EBP sensor, OEM only, as long as your tube is still free of obstructions, doesn't have any holes in it, and all connections are tight. You can try cleaning the sensor if it looks to be clogged. Some have had success with this, I have not.
http://www.riffraffdiesel.com/exhaus...-sensor-94-04/
Old Nov 6, 2015 | 08:25 PM
bigfordandjeep
Psi reading or voltage reading?
Old Nov 6, 2015 | 09:01 PM
Jaime74656's Avatar
Jaime74656
Boost is one item that will be on the OBD2 port
Old Nov 6, 2015 | 09:11 PM
jhl3's Avatar
jhl3
PSI.........
Old Nov 9, 2015 | 02:53 PM
bigfordandjeep
Closing this one out. Took edge off. Runs normal when cold now. Installed ts chip and reset mileage. So far it's been at 17. Happy! Thanks for all the help. I want new injectors still, however I want a new turbo too. Need to make my mind up on which route I want to go.
Old Nov 9, 2015 | 03:01 PM
  #28
Zwalters's Avatar
Zwalters
Better the turbo first then the injectors. With big injectors, your turbo may not be able to handle what they can throw at it.
Old Nov 9, 2015 | 03:08 PM
  #29
bigfordandjeep
Didn't mean one or the other. I plan on doing both at same time.
Old Nov 9, 2015 | 04:22 PM
  #30
Nicmike's Avatar
Nicmike
Veteran/Sheepdog
Make sure you take steps to protect that tranny from the bigger sticks and turbo. They will gang up on it and beat it to death...
Nathan_FM
Jan 1, 2019 04:40 PM
sand_fiend
Dec 29, 2018 11:59 PM
dmueller71
Feb 14, 2018 07:17 AM
lionsteve
Jul 10, 2017 02:28 PM
J. Kearney
40
Jan 14, 2007 07:39 AM
