Here is the Vin/Data plate on my 61 F100 I just recently purchased. Any decoding help would be much appreciated. I tried searching online, and came up with some info, but not everything. Thanks a bunch.
9985 = Domestic Special Order number. Truck was special ordered by original purchaser, not "bought off the lot."
*No COLOR code stamped on the Warranty Plate: Vehicle painted a non standard color per the original purchasers order, making it a Domestic Special Order.
1961 and 1962 Ford F100 (as well as other models like 4x4) are the same for these rear axles codes. This is from the 1957-1963 master parts catalog from Ford combined with other information from ND.
11 = Ford 9" Rear Axle / 3.70-1 / non Limited Slip / 3,300 lb. Rear Axle Capacity.
12 = Ford 9" Rear Axle / 3.89-1 / non Limited Slip / 3,300 lb. Rear Axle Capacity.
13 = Ford 9" Rear Axle / 4.11-1 / non Limited Slip / 3,300 lb. Rear Axle Capacity.
