Air Bag Help
Old Dec 17, 2015 | 03:28 PM
  #31
Irelands child's Avatar
Irelands child
Originally Posted by Air Lift Company
Try playing with the pressure a bit, should take the harshness right out of it.
If the trailer was empty, the hitch weigh is only about 2200 pounds in that Heartland model and a bit less then our Montana. I travel with 30 pounds in the bags and 10 pounds unhooked. I have tried as high as 40 psig and it rattled me and everything connected to the truck All you need to do at first is hook up, then add air until the truck and trailer are pretty close to level and you will have a good starting point. From that point you experiment. As far as driving VT and MA roads - they are 'golden' compared to many - even the hinterland roads in Central VT.
Old Dec 18, 2015 | 09:28 AM
  #32
ct diesel's Avatar
ct diesel
thanks will do it in the spring.
Truck Guy99
Dec 9, 2013 04:01 PM
MOC
Apr 16, 2012 07:36 AM
tampacamper
6.7L Power Stroke Diesel
18
Nov 9, 2010 10:43 AM
weldboy
Nov 29, 2005 02:20 PM
CNY_AF32D
May 27, 2005 03:45 PM
