Scale weight - can it possibly be right???
Old Dec 16, 2015 | 07:54 PM
FatOldGuy's Avatar
FatOldGuy
So I have a 1951 Ford 8N tractor with a bucket loader on it. I'm not sure how much it weighs, so I had it on the trailer today and decided to stop at a local truck stop with certified CAT scales and get myself weighed. I have never used the scale before, but it's not rocket science. But I'm not sure if I am reading the ticket right, and if I am, then there is no way it can be correct - at least I don't think so.
So I have a 2016 F350 XL 4x4 SRW Long Bed. The Ford specs for my truck says 7,720 lbs Curb Weight. Here is what the certified scales said:
Steer Axle === 5,000 lbs
Drive Axle === 6,340 lbs
Trailer Axle == 3,060 lbs
Gross Weight = 14,400 lbs
How can that possibly be accurate???
Old Dec 17, 2015 | 01:52 AM
BruteFord's Avatar
BruteFord
I don't see a problem assuming a 5th or goose trailer and the tractor loaded too far forward.
Old Dec 17, 2015 | 05:05 AM
senix's Avatar
senix
Yeah, it would appear you need to maybe turn the tractor around to put more on the trailer perhaps, or moved to center of axle.
Your weights are in line with reality.
Curb wt vs actual are much different.
Unloaded your rear is probably about 3100 lbs.
Old Dec 17, 2015 | 05:09 AM
BruteFord's Avatar
BruteFord
Not really enough info to go on, steer seems high and trailer light but that could be loading, the pin too far forward, crew cab diesel, etc. As Senix said these truck are heavier then the manufacture lets on, my crew 4wd diesel has about 4000 on the front axle empty.
Old Dec 18, 2015 | 12:22 AM
Destroked 450's Avatar
Destroked 450
I'd say you pulled on the scales wrong and weighed the trailer front axle with the trucks rear axle combining the two together. Take 3000 lb off the drive axle weight and add it to the trailer, that will give you a truer weight as I don't believe you can load the tractor far enough forward to only have 3060 lb on the trailer.
Old Dec 18, 2015 | 06:32 AM
FatOldGuy's Avatar
FatOldGuy
Bingo! I went back again yesterday and made sure I was on the scales correctly this time. The first time it was operator error and I had pulled too far forward. Here are my numbers from yesterday...
Steer Axle === 4,620 lbs
Drive Axle === 3,520 lbs
Trailer Axle == 5,640 lbs
Gross Weight = 13,780 lbs
The only difference besides getting lined up correctly is that I was outside the truck to push the button, so 250 less for that.
Thanks for all the info!
Old Dec 18, 2015 | 07:10 AM
senix's Avatar
senix
Now it would appear that your front is a bit heavy.
Are you using a wt distribution hitch?
Old Dec 18, 2015 | 07:34 AM
FatOldGuy's Avatar
FatOldGuy
Why does it seem bad now? It's lighter than before? I have a regular hitch except one that has a scale built in. The hitch scale reads a little over 500. Here's a pic of the tractor and trailer as it was weighed, except it's not attached to the truck.
Old Dec 18, 2015 | 11:04 AM
Destroked 450
If that's a pic of it and it's a crew cab it'll have a good amount of frontend weight, if it's diesel and or 4x4 the weight keeps adding up.
Your truck with 500lb tongue weight is 1100lb lighter than my F-450 is empty with no trailer (9280lb empty truck, full tank of fuel, no driver).
Old Dec 18, 2015 | 11:10 AM
FatOldGuy's Avatar
FatOldGuy
Yep, sorry for the lack of info, I will update my sig. It's a Crew Cab 6.7l diesel 4x4.
Old Dec 18, 2015 | 11:28 AM
Destroked 450
Run the empty truck across the scales that way you'll know how the weight is transfering next time.
Old Dec 18, 2015 | 12:47 PM
FatOldGuy's Avatar
FatOldGuy
Good idea. Thanks.
Old Dec 18, 2015 | 06:29 PM
Ferguson65's Avatar
Ferguson65
I checked for the scale weight pics but don't have them. 4600 on the front axle with the 6.7 is pretty close. Weighed my buddies 2011 dually before I bought mine and I'm near positive the dually front axle came in 46-4800. I'd call what your doing good, mark the trailer so you can easily put the tractor in the same spot next time. A hair more on the pin wouldn't hurt, but long as it tows ok not a big deal.
DelawareDead
All Things Towing
Feb 27, 2019 02:38 PM
dooger54
All Things Towing
33
Jul 26, 2016 12:56 AM
FatOldGuy
Dec 18, 2015 10:35 AM
Miller
2009 - 2014 F150
Mar 20, 2014 10:29 AM
rattleNsmoke
All Things Towing
Oct 10, 2011 06:09 PM
