EGR ISSUES
Old Aug 30, 2017 | 12:05 AM
grumpin's Avatar
grumpin
That's great! Thanks for the update!
Old Aug 30, 2017 | 01:29 AM
KULTULZ's Avatar
KULTULZ
Post
Originally Posted by 84Brougham
KULTULZ, thanks for the edit and the additional troubleshooting documentation. Between your information and other links on this site I have learned a lot about the EGR circuit.
You are more than welcome and you solved the problem w/o throwing parts at it...
I finally got some time to troubleshoot my EGR issue. With a hand vacuum pump/ gauge I confirmed the thermal vacuum switch, venturi vacuum amplifier (VVA) and EGR value were all working correctly. I found that the manifold vacuum line going from the carb to the VVA so connected to the incorrect vacuum port on the carb. So the manifold vacuum line on the carb was not providing variable vacuum (based on the throttle position) to the VVA so the VVA was not providing vacuum to the EGR valve. I connected the manifold vacuum line to the correct the vacuum port on the carb. After a test drive the EGR valve is functioning correctly.
I'm going to tell you what. This 'ol boy figured it out...
GOOD GOING!...
Old Aug 30, 2017 | 06:53 AM
CountryBumkin's Avatar
CountryBumkin
Interesting...
Why the check valve? It would appear that vacuum can be applied to distributor (and EGR when Temp is right), but with a check valve - how does the vacuum release?
It must have a bleed in the EGR/PVS valve (if so, it would need to be "normally open" so vacuum applied to distributor can be dumped and when there is no vacuum available due to throttle opening/position, the dist timing can return to base timing. Then, I assume, when engine temp is correct (hot), it then opens the top port sop vacuum can be applied to both the distributor and EGR. If that is the way it works, then EGR bleed (and distributor) vacuum bleed is through the EGR/PVS valve.
Still not sure why there is a check valve.
Old Aug 30, 2017 | 09:10 AM
KULTULZ's Avatar
KULTULZ
Post
That illustration is just a general/simplification of a system. The actual system(s) would most likely be more complex.
The check valve (in this instance) prevents a possible engine backfire from entering the system and causing damage.
Gary Lewis entered these ILL(s) on his website. Did you find them?
GeneGregory
Nov 9, 2016 03:39 PM
F100Mann
44
Feb 9, 2014 10:13 PM
ssanto
Dec 6, 2006 09:38 AM
Z-Burg
Apr 28, 2004 02:11 PM
1ole4d
Aug 6, 2001 01:51 PM
