How to check EGR functionality?
I've got an 85 F-150 with a 4bbl carb. I want to verify that the EGR is working. I took it off and plugged it into a vacuum line on my other truck... that line pulled 20 inches of Hg. The EGR I tested didn't move.
I went to the salvage yard to get another one and all four that I pulled and tested did not move when connected to vacuum.
Am I testing them wrong? How should I verify their operation?
Thanks,
Sal
You must have just gotten four bad ones in a row. If you're hooking it up to a strong engine vacuum like that and getting no movement, the EGR must be bad. Try pushing on the pintle in the the opening where it bolts to the manifold and see if it moves away and then retuns to close the valve when you release it. If it moves freely, then apply a vacuum to it. and see if it moves on it's own.
