Steering column questions
Old Oct 29, 2015 | 02:59 PM
Jimbo484's Avatar
Jimbo484
I have a 1965 Ford F100 that I am interested in swapping out the current steering setup for a power steering tilt steering setup. Is there a newer model that I can interchange with mine completely? I want one that I can buy complete and not have to do a lot of hunting for solutions. My friend has several older model trucks but doesn't know which will work. I appreciate the help. I am sure it is probably been done on this site before but I can't find it. Thanks for you replies.
Old Oct 29, 2015 | 04:45 PM
jowilker's Avatar
jowilker
A 78-79 Lariat tilt column, with matching Saginaw gear & pump is the only direct bolt up that I am aware of. Beware of parts guys claims of other models that it was available on. If it aint a Lariat you aint gonna find it.
The column can easily be modified to work, but the above is the only bolt on.
John
Old Nov 1, 2015 | 08:50 PM
Jimbo484's Avatar
Jimbo484
Thanks for the info. I just thought that lots of steering column exchanges had been completed many times. I think I'll just get used to not having power steering again.
Old Nov 2, 2015 | 05:06 AM
jowilker's Avatar
jowilker
Jim re-read your question, you said "a power steering tilt steering setup" not a power steering setup. You framed your question to imply it had to be as factory as could be. "Is there a newer model that I can interchange with mine completely?"
Do you feel you need to adjust?
John
Old Nov 2, 2015 | 02:44 PM
Crop Duster's Avatar
Crop Duster
davbell22602
WTB - Parts & other
Dec 12, 2011 02:13 PM
zombiesawyer
Feb 2, 2010 04:37 PM
whayes75
Aug 25, 2008 07:19 PM
inlandsurf
Dec 19, 2006 02:17 AM
cole_boy
Dec 23, 2002 07:12 PM
