Loose Pinion
Old Nov 9, 2015 | 03:14 PM
  #31
Freightrain's Avatar
Freightrain
.025 backlash. Ya, she's got plenty of miles on her. Should be 1/2 that(like ultra said).
If the gears look nice and the bearings aren't sloppy, then you could run it. Somebody else was. You could tighten the lash up a bit and see how the pattern looks and see if it gets noisy.
If you get everything cleaned up nicely, you can roll the gears using the pinion and you should be able to feel any vibration. That will tell you if they are noisy. Any vibration will turn into a "ring" or howling noise at speed.
Hooked Too
Oct 15, 2017 11:20 AM
Thisguy65
19
Jun 8, 2017 11:44 AM
xlt4wd90
Dec 13, 2010 04:13 PM
psychomech
Mar 18, 2008 10:51 AM
brokebronco
Jul 26, 2002 01:22 PM
