Hydroboost question
Old Oct 27, 2015 | 03:08 PM
yasky69's Avatar
yasky69
Hydroboost question
2007 F350
I noticed I have a small power steering leak where the master cylinder bolts onto the hydroboost. Is there a o-ring or seal between the two? or do I have to replace the hydroboost?
Been looking online for a schematic but can't seem to find one.
Old Oct 27, 2015 | 03:46 PM
TooManyToys.'s Avatar
TooManyToys.
You need to replace the HB.
Old Oct 27, 2015 | 05:24 PM
69cj's Avatar
69cj
It could also be a seal in the master cylinder. If the master is leaking it can leak between the two units.
Old Oct 27, 2015 | 06:55 PM
TooManyToys.
It can, which is more common. I just felt if he says PS fluid, he knows PS fluid.
Old Oct 27, 2015 | 08:56 PM
texastech_diesel's Avatar
texastech_diesel
Token Redneck
Book doesn't show a seal between the MC and HB units. Not that the book does always show everything, but for example on fuel injectors it specifically addresses the seals in the Motorxraft seal kit, so if a seal was vital it seems like they'd show it.
Old Oct 27, 2015 | 11:09 PM
TooManyToys.
The seal is in the HB, and not field serviceable. The area between the M/C and HB is "dry".
The typical failure mode is for the rear sealing cup of the M/C to have a slight brake fluid leak. Then the truck starts to develop dragging brakes with two brakes on an axle or all four brakes at the same time (Not the cause of one wheel brake hangup) due to rust buildup between the HB pushrod and the M/C piston. You can remove the two M/C retaining nuts and pull the M/C forward and it will have rust particles drop out.
If the truck was a vacuum boosted truck the brake fluid would be pulled into the intake manifold or vacuum pump if it was a diesel.
Old Oct 28, 2015 | 12:55 AM
yasky69's Avatar
yasky69
Its without question PS fluid, I have to refill that at least once every month with a bottle. Brake fluid has never changed.
Anyways it comes out on the bottom side of where the two mounting bolts go to mount the MC to HB.
Has anyone used the reman HB? or stick with OEM and new
Old Oct 28, 2015 | 08:02 AM
69cj's Avatar
69cj
My money without seeing it is on the master cylinder.
Old Oct 28, 2015 | 08:11 AM
yasky69's Avatar
yasky69
Where does the PS fluid come in contact with the MC?
Old Oct 28, 2015 | 04:03 PM
texastech_diesel
Token Redneck
By "power steering fluid" you mean ATF right?
Old Oct 28, 2015 | 05:19 PM
69cj's Avatar
69cj
Sorry, I ozoned when you said PS fluid and had brake fluid in my mind.
Old Oct 29, 2015 | 07:11 PM
yasky69's Avatar
yasky69
Is this a test to see if I know the difference between BF,PS and ATF?
No problem, I asked just in case I had misunderstood how the hydroboost works.
Old Oct 30, 2015 | 08:52 AM
texastech_diesel
Token Redneck
The power steering/hydroboost system on this truck uses ATF and not necessarily stuff from bottles labeled "power steering fluid". If you're adding the green mineral-oil based power steering fluid it's not the correct stuff.
Old Oct 30, 2015 | 12:13 PM
69cj's Avatar
69cj
The correct atf is Mercon V.
pueblojon
Jun 5, 2014 04:59 PM
okie72
Feb 15, 2014 09:35 PM
pappie
Aug 21, 2008 08:33 PM
tiljc
Jan 17, 2005 04:16 PM
TxBrokenarrow
Sep 21, 2004 03:51 PM
