I have a 94 ranger 3.0L with a bad pinging problem. I've read all the posts here on this topic and cleaned all the right things, replaced fuel filter and air filter. I swear this truck does not have a EGR valve. I have looked up and down on this motor for it. I can't find any tap off of the exhaust to follow, and I can't find any valve (other than the IAC) on the intake. There is a block off plate on the intake by the IAC. Looks factory to me, but is this where the EGR should be. I can't find the DPFE either or the octane shorting bar.
Oh, and when I unplug the connector on the distributor (I believe it's the SPOUT connector) the car dies instantly.
I'm about to chuck thi truck and get a F150, or dare I say....a GM
If you cannot locate the DPFE and EGR valve after reading through the links in this forum and reviewing the pictures that were posted, then I have a feeling that you may have a different type of EGR system on your motor.
You may have the EVP System which is a little different setup than the DPFE System.
I was able to get this out of a '94 Ford Manual:
There are two basic types of EGR systems:
- The PFE/DPFE System
- The EVP System
All EGR valves are vacuum actuated. The vacuum diagram is shown on the emission decal for each calibration......
The EVP EGR Valve is required in EEC systems where EGR flow is controlled by the Powertrain Control Module (PCM) through an EGR Valve Position (EVP) sensor attached to the valve.
The valve is operated by a vacuum signal from the EGR Vacuum Regulator (EVR) Solenoid which actuates the valve diaphragm.
As supply vacuum overcomes the spring load, the diaphragm is actuated. This lifts the pintle off its seat allowing exhaust gas to recirculate (flow). The amount of flow is proportional to the pintle position. The EVP sensor mounted on the valve sends an electrical signal of its position to the PCM.
well, that sucks. Any idea where the EGR and the EVP is located?
I think I've traced every vacuum line off the intake possible and can't find anything looking close to these. And there is no pipe, slash hose from the exhaust manifolds back to the engine compartment for the EGR circuit.
Maybe someone else out there with your generation motor can help you with the actual location of the EVP EGR components, since I am not really familiar with that kind of setup.
Also, did you buy the truck used? Maybe the previous owner yanked the EGR system off of the motor. I've heard of that happening before...
You are not crazy there is no EGR system on your engine. I also have that engine. i work at an ford dealership and have inquired about as to how it works but have had no reply
I've also been reading posts in some other forums from guys who have said the same thing ...they cannot find an EGR system on their '94 3.0L.
If you do get any feedback on the issue from anyone at your dealership, please post it.
P.S. It's a good thing the '94 vulcan engines have knock sensors, otherwise I bet they'd ping like crazy since they have no EGR system to keep the combustion chamber temperatures down.
Hey man, i just posted this same question in another part of this forum. I have a 91 Ranger with a 3.0L and i couldn't find the EGR valve either. But i did find the plate that the gasket fits to.
I removed the plate and looked inside a dark hole that had some oil residue puddled in there. I soaked up the small amount of oily substance and replaced the plate with a new EGR gasket that i paid $1.59 for. I thought it to be really weird that there wasn't any EGR vlave on this motor.
I'm glad that it's not just my ranger that this has happened to and mine is 3 years older than yours!
I've been doing some digging on the subject of DPFE sensors and EGR valves, and whether or not they even exist on the earlier 3.0L Rangers. I think I've come up with something.
The Ford Manual for 1993-94 Rangers has a wiring schematic showing the various sensors and how they are connected to the computer and each other. One of the sensors it shows is the DPFE. However, the manual says that the DPFE is only applicable to engines 'Built After 4/5/93" and that the DPFE is "Not On 498 M/T".
This seems to indicate that the DPFE (and hence the DPFE/EGR system) was not used on the 3.0L Ranger until sometime during the 1993 year, and also probably not used on some trucks through at least a portion of 1994, since I assume that many vulcans built before 4/5/93 were still being installed in some early 1994 models as the engine stock was being used up and replenished with the newer EGR-equipped motors.
