front brake rotor
Old Oct 26, 2015 | 05:30 PM
peka's Avatar
peka
front brake rotor
84 F250 4x4 351w, will the front brake rotors come off the hubs, it looks like it does. But it does not want to.
Old Oct 26, 2015 | 08:17 PM
Diesel_Brad's Avatar
Diesel_Brad
Did you remove the hub/rotor from the truck?
Did you remove the 8 wheel studs?
Did you hit the rotor to unlodge it from the hub?
Old Oct 26, 2015 | 10:13 PM
peka's Avatar
peka
Hub/Rotor is on bench. Did not know about removing studs. Do I just press them out?
Old Oct 26, 2015 | 10:22 PM
Lowpala's Avatar
Lowpala
Unless the f250 is different than most, yes they are pressed in. I've always just used some pb blaster with a lug nut screwed on the stud and drive it out.
Old Oct 27, 2015 | 06:53 AM
Diesel_Brad
I just hit the stud squarely with a large hammer, pops them right out. Do the same to install them
Old Oct 27, 2015 | 02:01 PM
peka's Avatar
peka
Pressed them out in 10 min. Disc fell off, Thanks for the help.
Btoddsmith
6.4L Power Stroke Diesel
Mar 22, 2013 09:46 PM
natedog37
Jun 5, 2010 12:03 AM
Clearsound
25
May 22, 2007 10:42 AM
89fourx4
Jan 18, 2007 07:48 AM
xsquid3
Oct 4, 2006 01:46 AM
