6.4L Power Stroke Diesel Engine fitted to 2008 - 2010 F250, F350 and F450 pickup trucks and F350 + Cab Chassis
Brake rotor
Old Mar 22, 2013 | 11:36 AM
Btoddsmith's Avatar
Btoddsmith
Brake rotor
Does the front brake rotor on 2008 f-250 4x4 come off without unpacking wheel bearings ? Thanks
Old Mar 22, 2013 | 12:19 PM
UGA33's Avatar
UGA33
Yes it does.
Old Mar 22, 2013 | 01:34 PM
Btoddsmith's Avatar
Btoddsmith
Roger that , thanks
Old Mar 22, 2013 | 01:41 PM
senix's Avatar
senix
Spray around it at the lug nut studs and around the hub.
Hammer and brass punch give it a couple of wacks evenly around the rotor in between the studs and it should break loose.
Old Mar 22, 2013 | 02:01 PM
Btoddsmith's Avatar
Btoddsmith
Thanks , I will soak them in penetrate early . Can the rotors be turned ? How many usually ?
Old Mar 22, 2013 | 09:46 PM
UGA33's Avatar
UGA33
Depends on how much meat you have on them left and their overall shape. I plan on doing mine in a couple of weeks.
peka
Oct 27, 2015 02:01 PM
jdgreen72
Oct 31, 2007 12:18 PM
krewat
Aug 22, 2005 09:37 PM
IronWorker3
Jan 16, 2005 08:08 AM
