Front Brake job help?
Old May 2, 2010 | 05:45 PM
natedog37's Avatar
natedog37
I am posting this for my brother who has a 91 f250 4x4, he is having a heck of a time doing his front brakes. He can't seem to get his rotors off to replace them. Does anybody have a step by step guide or link that I can print off for him and get him back on the road? I'm not sure what tools he has, so if there is something special he needs can you give me a heads up. Thanks in advance.
Old May 2, 2010 | 05:53 PM
Sycostang67's Avatar
Sycostang67
The only special tool you need is the hub socket. Once the rotor/hub assembly is off, you have to remove the wheel studs to separate them.
Old May 2, 2010 | 11:50 PM
LCAM-01XA's Avatar
LCAM-01XA
Yes, what he said - first you take the locking hubs apart, then you pull the spindle nut, then slide the whole wheel hub and rotor as one, then beat the studs out - one all studs are out the rotor will separate fro the wheel hub.
Old May 3, 2010 | 12:29 AM
natedog37's Avatar
natedog37
OK thanks guys, I'll pass it on.
Old Jun 3, 2010 | 04:30 PM
natedog37's Avatar
natedog37
Exclamation My bro still needs help!
Ok, so after waaaay to long in my brothers drive way, he trying to get his front hubs back together and came across a little gear that he doesn't know where it goes. It seems to fit either right in the front of the hub or at the rear. It nestles in good at the front of the hub so that is my vote, but it's always better to ask when we don't know, right? right! Before you ask, he did try taking the passenger side apart and looking but, that side didn't have the little gear, or at least he couldn't find it. He also tried to go the the junk yard for some recon but, they don't have an intact hub. Any help would be great! Also if there is any liks to a schematic that would be great too. Thanks.
P.S. I have pics but I don't know how to post em'
Old Jun 3, 2010 | 09:44 PM
Dave Sponaugle's Avatar
Dave Sponaugle
Sounds like one of the parts of the lock out hub.
Some of them are one piece units, some of them come apart in pieces.
If that is what I think it is, should slide in from the outside and has a spring behind it.
Old Jun 4, 2010 | 12:26 AM
rupejosh's Avatar
rupejosh
yup!!!! sounds like the same to me
Old Jun 4, 2010 | 05:42 AM
Cruickie's Avatar
Cruickie
Based on what Dave S and Rupe said is sounds like you have manual locking hubs (my manual shows both for 91 F20 4x4)
The exploded view of the manual hubs aren't as detailed as teh automatic hubs but:
and
Exploded view of automatic locking hub:
Hope this helps!
Old Jun 4, 2010 | 10:24 AM
natedog37's Avatar
natedog37
Thanks all!
OK, judging by the exploded view, it looks like it is the spacer behind the hub. I will let him know this morning, and hopefully get him back on the road!
Old Jun 4, 2010 | 10:31 AM
510guy's Avatar
510guy
i know its too late now but in future tell him when he takes things apart to lay them out on a rag in the order he removed them, i would do that at work when i wasnt sure or it was the first time i did something. i just saves a headache down the road and also jogs your memory a bit.
Old Jun 5, 2010 | 12:03 AM
Sycostang67
Thats the way I do it as well, real handy when working on drum brakes, hubs, carbs, etc..
RV_Tech
All Things Towing
34
Aug 29, 2015 04:29 PM
dave91gt
Oct 30, 2011 03:42 PM
johnny-old-truck
Dec 8, 2010 11:10 PM
Codys 85 Ranger
Mid-West Region
Jun 6, 2007 05:26 PM
BigMattXXL
52
Dec 20, 2003 11:22 AM
