I picked up a beater f250. The truck is an 84 with a newer year 300 i6 in it. Im not sure what year the engine is. The carb is a 1 barrel and the only numbers I can find are 7599S.
Electronic carb- They are rebuildable, but kinda pricey and tricky to make run right. You may just want to scrap the whole setup and go with an intake and 2BBL carb. BTW, I believe that is a Motorcraft carb.
Are you sure the carb is stamped 7599S; I have this carb but it is stamped 7598S (Ford # E4TZ-9510HX)- I had to look through a magnifying glass because the "8" had a weak stamp imprint.
