Replacing front wheel bearings, anything else?
Old Oct 24, 2015 | 10:51 AM
Jesser02EX's Avatar
Jesser02EX
I have some whine coming from my front wheel bearings so I'm going to replace them both.
I'm not sure if this had been done on my truck before, but I'm thinking so since I have Moog greaseable ball joints.
Truck has 250k miles on it. I'm going to check the pads, rotors and slide pins. Anything else that might need work?
I'm sure the half shaft could use a once over, but I don't keep my hubs locked so they don't turn much in regular driving.
Looking for FTE thoughts.
Old Oct 24, 2015 | 03:55 PM
scotttahoe's Avatar
scotttahoe
Maybe the axle dust seals. You do need to make a custom seal driver which is an easy stop at the local hardware store.
This is everything I replaced on my truck. You can see the seal driver tool that I made on the far right sitting on the concrete.
That is the old seal coming out. But you can see why you need that long seal driver as it has to fit around the axle shaft.
With it all finished up. Use some paint to make her all pretty!
Old Oct 24, 2015 | 04:14 PM
Jesser02EX's Avatar
Jesser02EX
Thank you. Do you have a p/n for the dust seal?
Also which break pads did you use? I've read "hawk" but unsure on which pad for someone who doesn't tow a ton.
Old Oct 24, 2015 | 05:05 PM
scotttahoe's Avatar
scotttahoe
Give me a second to try and find the part numbers for the dust seals. I did the inners and outers. The pic above shows the inner dust seal that goes on the axle hub. The outer one goes on to the knuckle itself. A bad pic but you can see the seal.
For the brake shoes, I just used the Napa premiums.
Old Oct 24, 2015 | 05:07 PM
scotttahoe's Avatar
scotttahoe
When doing the seals make sure you get in there and sand down the metal where the seal mates so it's all nice and clean.
I'm not at home as I'm watching the bosses dog at his house for a month and I don't have the Napa part numbers from the receipt but will look them up. I'll try and find the Ford part number for you.
I believe the larger inner seals are actually from ford and the smaller outer seals were from Napa.
Old Oct 25, 2015 | 03:12 AM
Bently_Coop's Avatar
Bently_Coop
Here is a how to link and list for part numbers on a 2004 F250. Jason is also a FTE member. 1975stroppebaja is the screen name.
2004 F250 Ball Joint Replacement
Old Oct 25, 2015 | 03:35 AM
glockholiday's Avatar
glockholiday
I just had a vacuum line break to one of my front hubs causing my 4x4 and HVAC to act up, while you're in the fender well might as well throw $3 worth of new vacuum line in there.
Old Nov 1, 2015 | 10:34 PM
Jesser02EX's Avatar
Jesser02EX
Thanks for the tips. I successfully completed the hub swaps today. Everything is so heavy in these trucks. So happy ford built these right!
10bands
Jul 22, 2018 03:27 PM
pgguru
May 28, 2014 08:05 PM
wrxin
May 28, 2013 08:19 PM
Piolet
Apr 23, 2013 09:32 PM
Trailblazed
21
Mar 3, 2008 10:05 PM
