vacuum pump issues???
Old Oct 24, 2015 | 10:21 AM
bearded driver's Avatar
bearded driver
Hello to all.
I own and daily drive a 92 f250 7.3 idi na diesel
can the vacuum pump be serviced? Mine is going out unfortunately. I remember reading some where that it can be oiled.
Old Oct 24, 2015 | 11:51 AM
EYEDEYE's Avatar
EYEDEYE
I just installed a new one and the instructions clearly state never to oil it. I have read on the forums that air tool oil may work, since it may not hurt the diaphragm. If it is indeed going out...ya got nothing to lose.
Old Oct 24, 2015 | 02:07 PM
jdemaris's Avatar
jdemaris
Originally Posted by bearded driver
Hello to all.
Oil what part of it??? Vacuum pump is two parts. One is the drive that has sealed ball-bearings. The other is the pressed-together tin-can that has the vacuum diaphram and check-valves inside. Oiling the sealed bearings certainly won't help anything. Nor will oiling the vacuum diaphram.
Old Oct 24, 2015 | 02:13 PM
bashby's Avatar
bashby
There is a cam inside that transfers the rotation into a up and down motion
that moves the diaphram. I seem to remember where people would use a synthetic
lube. I think you have to remove a pressed in cap to change the lubricant. If your pump is
going out I doubt that would help. If its not pumping enough air you probably have a problem with the diaphram or check valves. AFAIK, there's nothing you can do with that.
Old Oct 24, 2015 | 02:23 PM
jdemaris's Avatar
jdemaris
Years back - you could buy just the replacement tin-can with a new diaphram and check valves. Use to cost around $50 from CAV. For Ford or GM. Not worth it anymore since a complete new pump is pretty cheap. I bought one a few months ago for $60.
Old Oct 24, 2015 | 03:45 PM
bashby's Avatar
bashby
Now that you say that, I think to lube the cam you just pull the diaphram can off and dump the oil
out and replace with new synthetic. Dont know what weight.
Old Oct 24, 2015 | 04:18 PM
bearded driver
Thanks guys. I guess ill just buy a new pump no worries.
Old Oct 24, 2015 | 04:57 PM
bashby's Avatar
bashby
Id check rockauto. They arev usually quite a bit cheaper
than local and a selection of brands to chooose from.
Old Oct 24, 2015 | 08:32 PM
EYEDEYE's Avatar
EYEDEYE
I got mine from Rock Auto last week...$86 shipped.
Old Oct 25, 2015 | 08:01 AM
tjc transport's Avatar
tjc transport
i ain't rite
changing the oil in a vacuum pump is usually a waste of time because when it stops making vacuum it is usually from a ruptured diaphragm.
SClemens
6.7L Power Stroke Diesel
Aug 18, 2020 09:15 PM
MTB17
25
Feb 8, 2018 10:47 PM
danlee
Mar 23, 2017 09:27 AM
2002_F-250
Apr 21, 2011 08:20 PM
juggernaut239
Jul 3, 2009 06:52 PM
