Interrmitent Wipers
Old Oct 21, 2015 | 03:48 PM
bcamill's Avatar
bcamill
Interrmitent Wipers
OK, so I read on the threads that this was an easy plug and play upgrade. I went to Autozone and made my purchase. I installed the new switch and ground the black wire to the dash. Turned it to intermittent and nothing. Turned to low and nothing. Turned to high and the wipers moved halfway up and the switch was clicking rapidly. Did I get a faulty switch or am I missing something?
Old Oct 21, 2015 | 05:08 PM
JimsRebel's Avatar
JimsRebel
Did it look like this....
Delay Wiper Motor Switch Wiring Harness Plug and Delay Module Windshield Wiper | eBay
Jim
Old Oct 21, 2015 | 05:17 PM
bcamill's Avatar
bcamill
No, it was all in the switch that looks like the one without intermittent, with the exception it had a small box below it. I am guessing that is the intermittent part. No where as big as that one.
Old Oct 21, 2015 | 05:35 PM
JimsRebel's Avatar
JimsRebel
So if you bought this...
Duralast/Windshield Wiper Switch SW1112 at AutoZone.com
Autozone Part Number: SW1112
You will still need the delay module, the black square box, to make it work.
Jim
Old Oct 21, 2015 | 05:42 PM
bcamill's Avatar
bcamill
Jim
OK, I get it. That is exactly what I bought. Thank you.
Old Oct 21, 2015 | 05:51 PM
ArdWrknTrk's Avatar
ArdWrknTrk
pedant
A delay switch should *not* be able to plug into the truck harness, only into a delay module.
It is the delay module that has a plug that matches the truck harness socket.
Old Oct 21, 2015 | 08:54 PM
ctubutis's Avatar
ctubutis
Yeah... it would take some, um, re-engineering to mate the two....
Old Oct 22, 2015 | 09:34 AM
bcamill's Avatar
bcamill
Where is a good place to get a delay module. I was unable to locate one from Autozone.
Old Oct 22, 2015 | 09:46 AM
ArdWrknTrk's Avatar
ArdWrknTrk
pedant
They are stupid expensive from Ford and I don't know of any in the aftermarket.
Best bet is eBay or the junkyard.
Not all trucks have a wiper **** that turns left but every bronco I've found does.
If you pull it yourself try and find a vehicle with automatic because jarring from the parking brake release destroys them, though you can resolder the heatsink inside.
Old Oct 22, 2015 | 09:50 AM
ArdWrknTrk's Avatar
ArdWrknTrk
pedant
Also, Ford tsb suggests don't mount them on the arm to the parking brake.
Wrap them in foam rubber and zip tie it up behind the fuse panel.
I haven't had to repair mine since I left it off the bracket.
Old Oct 22, 2015 | 10:15 AM
bcamill's Avatar
bcamill
Thanks, I went to Ebay and one is on the way. I am sick of the switch when it is misting.
75highboy390
29
Jul 14, 2013 10:27 PM
The Masked Rider
17
Oct 4, 2012 05:41 PM
donmi
Aug 27, 2012 11:44 AM
80FlareSide
Jul 23, 2012 11:25 AM
broncoholic
Electrical Systems/Wiring
Mar 1, 2004 04:17 PM
