trailer brake controler
Old Jan 6, 2016 | 06:07 PM
rla2005's Avatar
rla2005
Originally Posted by suaveGato
Hello,
In post #6 there is a picture of a 7 pin trailer plug receptacle with the the 2 stock pig-tail connectors on the ends... Does anyone know a manufacture, part number or where to buy this? I need this for my 92 F350.
Thanks
Ford 3U2J14B475KCA, 3U2Z14S411KCA
Motorcraft WPT421
The photo from Rockauto is a bit misleading but it is supposed to have the 4 and 3 pin connectors on the end of the leads.
More Information for MOTORCRAFT WPT421
I am not sure if it is still available. The last time I checked in 2011/2012 it was $116 USD.
<table border="0" cellpadding="0" cellspacing="0"><tbody><tr><td style="vertical-align: bottom;">
</td><td>
</td></tr></tbody></table>
Old Jan 6, 2016 | 06:19 PM
suaveGato's Avatar
suaveGato
^ THANK YOU rla2005! That's what I needed.
Old Jan 6, 2016 | 06:37 PM
suaveGato's Avatar
suaveGato
Motorcraft WPT421
</td><td>
Hmmmm, I found this "Motorcraft WPT421" part online but the sites are saying it is NOT the right fit for my 92 F350 XLT? I have the the two connectors at the bumper (black & gray) one has 4 wires, one has 3... Anyone know if this part will indeed fit?
Thanks,
Old Jan 6, 2016 | 07:20 PM
rla2005's Avatar
rla2005
The trailer wiring is the same on 1992 to 1996 F150/Bronco and 1992 to 1997 F250/350. I found another part number for the harness: F6TB-13A576-BA
Another tidbit of information from Steve83: http://www.supermotors.net/registry/media/670235
Old Jan 6, 2016 | 11:25 PM
suaveGato's Avatar
suaveGato
^ Thank you!
Old Jan 8, 2016 | 02:17 PM
suaveGato's Avatar
suaveGato
well, having some challenges finding that last part... The 7 pin socket with the 2 connectors on the pig tail that plug into the truck (gray & black 4 pin & 3 pin). I found on on this site: Motorcraft - WPT421 ~ Wire Asy Motorcraft - WPT421 Wire Asy Part #3U2Z14S411KCA. I had the guy pull it and check to see if it physically had to two pig tail 4 & 3 pin connectors and it did not, just bare wires?
Any other idea where I could get one with the two connectors?
Thanks
Edit: just talked to Ford directly and they said the part is discontinued...? Oh well, I wanted to do the plug & play but looks like I may be splicing.
Old Jan 8, 2016 | 05:37 PM
rla2005's Avatar
rla2005
Sorry to see I got your hopes up for nothing....rats
Do an E-bay search on the F6TB-13A576-BA part number above. There are a few hits that are very close. F6TB vs. F6TB may only be a Bronco versus a F150. Same part.....be aware, they are pricey.
Old Jan 8, 2016 | 08:52 PM
78 PEB's Avatar
78 PEB
Originally Posted by Bird-Dog 250
I located the harness, but, looks like it had a controller at one time and the installer cut the plug off! There are scotch locks on the ends of the harness to where the old controller was wired. I've got the wires but are they ever short! If only people would take the time! It would have been easier for the guy to have used the pig tail instead of cutting everything! Now it's perseverance! I'll win!!
It really makes me mad when P/O's do that kind of thing. Do as others have suggested and go to a junkyard and get the plug with as much wire attached to it as you can. Then do a proper soldered and heat shrink splice.......no butt connectors.....it will never give you a bit of trouble and you can take credit for repairing it right.........especially if you ever sell the truck to me.......LOL
Old Jan 9, 2016 | 01:55 PM
suaveGato's Avatar
suaveGato
No worries, don't be sorry. I appreciate all of the help! THANKS
GuitarJesus
Jul 13, 2012 11:41 AM
wildstang
67
Jul 9, 2012 10:11 AM
buffalobob
13
Aug 25, 2008 07:49 PM
LogicalRetard
All Things Towing
Mar 22, 2005 11:47 AM
Frankenstang57
1997 - 2003 F150
Dec 23, 2002 09:35 AM
