Demonhawk, he is talking about the vacuum line running from the blender door vacuum solinoid located on the passenger side rear firewall. Top, left hand corner of your last photo.
I stopped at a salvage yard and found it.... It connects to the white vaccum line coming from the interior..thanks guys.
That's a great price for silicone hoses. And you're right, super thick walls, no risk of increased volume being an issue. Thanks for showing that, I'll be getting some.
Ok, if I can get this taken care of that should about do it. In the above picture, to the left of the Manifold, and behind the Heater hose there is some sort of valve/emissions piece. It is in-line with a vaccuum line on both sides and it has an electrical connection as well. (it is brass colored) you can just see it between the hoses. What is that? And lastly, the Air pump/diverter (front cnter of the photo) has two small vaccuum lines coimng off of it. I think one goes to the Manifold tree, but the other I am not sure.... it looks like it goes behind the EGR, probably near the TAB or TAD....does anyone know where it attaches? Thanks!
