I did a search on LED turn signals without finding any obviously useful posts.
Has anybody replaced the incandescent bulbs in their F250 turn signals with LED bulbs? If you did, were there any issues with the blink rate being too fast, or did they work ok? If there were issues with the blink rate, is there a replacement flasher that corrects that?
It all depends on what year truck, I believe some of the later models might work ok since they have a different flasher. Most of the older trucks have problems. It's a roll of the dice, you will just have to try it. If it doesn't work right there are load resistors you can buy and add to the LED lights to make your truck happy again.
