LED light upgrade issues
Old Jul 14, 2018 | 09:38 AM
_Hilljack_'s Avatar
_Hilljack_
I did a lot of research prior to upgrading all my exterior lights to LEDs and thought I had everything I needed before starting. I installed all the lights (brake, reverse, front markers, front turn signals) before testing them. Everything works except my turn signals which are somewhat intermittent. I replaced both of my flashers (hazard and turn signals) with electronic flashers. The hazards work fine with both the stock flasher and the electronic flasher.
Now the issue with the turn signals is somewhat strange to me. With the turn signal on I can see the light on the dash come one faintly and stays on (solid) as the turn signal is on but none of the exterior bulbs work. If I hit the side of my truck or bump the wiring they will flash once. If I hit the brake the bulbs will flash once. I had the truck running and got the turn signals to work without issue, shut the truck off and they kept working, then when I turned the turn signal off and back on they wouldn't work.
The only thing I can think of is a ground issue but I was thinking if it was a ground issue the hazards wouldn't work (but again, they are working). Anybody have any ideas?
Thanks
Old Jul 15, 2018 | 10:02 AM
tjc transport's Avatar
tjc transport
i ain't rite
not enough resistance in the circuit with the LED's.
Old Jul 15, 2018 | 10:51 AM
_Hilljack_'s Avatar
_Hilljack_
I thought the purpose of the electronic flasher was so it didn't matter how much resistance was in the circuit?
Old Jul 15, 2018 | 12:03 PM
tjc transport
i ain't rite
no idea, i have always used electronic flashers in my trucks due to the extra lights on trailers.
try using a regular light plugged into the trailer plug. if the lights work correctly with that setup, the issue is low resistance in the led's.
Old Jul 16, 2018 | 01:06 AM
TexasGuy001's Avatar
TexasGuy001
I think you may still need a pair of resistors at the tail lights. I know I had to in order for torque converter lockup to work.
Old Jul 16, 2018 | 02:12 AM
AK FORD GUY's Avatar
AK FORD GUY
I believe this is true with most vehicles, but our Fords are extremely sensitive to low bulb resistance and I have seen it cause all kinds of issues.
Old Dec 18, 2018 | 12:05 PM
_Hilljack_'s Avatar
_Hilljack_
Forgot to post this a while back. Turns out the electronic flasher I had just didn't work for the turn signals (worked fine for hazards). Bought a different electronic flasher and everything works perfectly.
Old Dec 18, 2018 | 07:10 PM
MPP8405's Avatar
MPP8405
I added load resistors to the signal circuits and an electronic flasher unit for mine, works nice, changed every bulb except headlights and the charge indicator light to LED, one of the best mods ive done yet.
Old Dec 19, 2018 | 12:25 AM
eagle275's Avatar
eagle275
Which one did you get? The one's I got wouldn't fit in front fuse area and couldn't get to flasher behind the box. Thanks!
Old Dec 19, 2018 | 07:36 AM
MPP8405's Avatar
MPP8405
Was a superbrightleds.com one I believe its the square red one with 2 flat spade terminals on the bottom
gtmustang00
Jan 25, 2014 10:17 PM
Number36Car
Nov 20, 2013 08:07 PM
cwatson1982
Jul 12, 2012 01:31 AM
ford4604bbl
Mar 21, 2010 01:36 PM
rogue s.
Feb 6, 2004 05:52 PM
