FICM Relay Question
Old Oct 20, 2015 | 11:57 AM
diesel_dan's Avatar
diesel_dan
Question FICM Relay Question
I see in my manual that the under-hood power distribution center has in slot 304 the IDM "High-Current Relay", which I think is the FICM Relay. is a "Full ISO Relay" something you could swap in its place, or are we talking a one-of-a-kind (as in carry a spare) relay?
Or also if I pulled it when I parked, it would be a safe (truck just turns over, but no damage done) theft deterrent?
Old Oct 20, 2015 | 12:12 PM
Toreador_Diesel's Avatar
Toreador_Diesel
FTE Leadership Emeritus
I'm no electronics expert, but I ordered one off amazon and replaced mine.
It's safe to pull as a theft deterrent, the most you'll have to do is replace the starter.
Old Oct 20, 2015 | 01:13 PM
Bullitt390's Avatar
Bullitt390
Certified Thread Hijacker
I pull mine when leaving my truck for extended periods. Engine will still crank of course but will not start.
Josh
Old Oct 20, 2015 | 01:30 PM
TooManyToys.'s Avatar
TooManyToys.
Me too. If someone is cranking with no start they risk someone coming over if they need help, not something a thief is going to want so they won't crank for long.
Yes, a flat bed or heavy lift helo could take it away, but I'll take that chance.
Old Oct 20, 2015 | 01:59 PM
BPofMD's Avatar
BPofMD
Veteran: Navy
Emerg brake on and wheels turned towards curb helps in that situation...... better to interrupt the ignition circuit tho....
Old Oct 20, 2015 | 02:12 PM
r2millers's Avatar
r2millers
While traveling last summer, we too, removed that relay as a precaution, not knowing the area very well and not wanting to wake up to an empty parking spot.
Thanks Pop's for the tip.
Old Oct 20, 2015 | 02:29 PM
diesel_dan's Avatar
diesel_dan
Thanks guys!
I think a hidden switch to kill the starter relay would be the other part of the hat trick. Need to figure out how to do that...
Old Oct 20, 2015 | 02:39 PM
TooManyToys.
Just go to the quick connect at the passenger fender.
Old Oct 21, 2015 | 06:50 AM
DSMMH's Avatar
DSMMH
To answer your original question, it is a one-of-a-kind relay and not interchangeable. The other large relays are 30 amps. I have found it to be a good practice to swap the 30s around periodically. Some are used a lot more then others.
I would highly recommend that anyone with a 6.0 with 100K+ on the truck that, as a preventative maintenance measure, change the FICM power relay. The contacts burn and pit and will not allow the proper amount of current to the FICM. Ask me how I know!!!!
Ed
Old Oct 21, 2015 | 07:35 AM
joe blow's Avatar
joe blow
If one were to....let's say find the power wire to the FICM circuit and in a round about way splice a switch and cleverly hide it somewhere in the cab for theft deterrent purposes.......would that switch hypothetically need to run through a relay as to not heat up?
Just thinking out loud and speaking in hypothetical terms to avoid getting flamed for such a taboo question on an open forum.
Thanks
Joe
Old Oct 21, 2015 | 07:55 AM
Bullitt390's Avatar
Bullitt390
Thanks
Joe
It would work, but my honest opinion would be to leave the FICM circuit alone.
Josh
Old Oct 21, 2015 | 09:44 AM
navistarnut's Avatar
navistarnut
Great to see these reminders of things easily forgotten. I am ordering one today. I highly doubt it's been replaced, but cheap insurance to do so and throw the old one in the cab as a known good spare.
Old Oct 21, 2015 | 02:16 PM
Yahiko's Avatar
Yahiko
Thanks
Joe
Josh
Also one thing to keep in mine you will need to down rate a switch by about 25% to give you a good
amount of overhead. So that you give you a 50 Amp switch. So it's not going to be tiny unless you use a relay.
Sean
6.0L Tech Folder
Old Oct 22, 2015 | 01:01 PM
white Buffalo's Avatar
white Buffalo
I need to do this soon.....just to be prepared.
Old Oct 22, 2015 | 02:19 PM
Yahiko's Avatar
Yahiko
If you really want to mess with then take an old
FICM relay and cut one of the large terminals off
and put that in when you want to part for a long time.
Sean
6.0L Tech Folder
