I'm wondering if anyone has considered lowering the chassis on the transit vans? I have an application where the mid-height chassis won't quite fit in our garage but it's just a couple inches too tall. I was thinking that a tire change and a different set of springs might make it fit. I'd love to hear from current owners that might have looked at this issue.
Hey Del...the stock tire size on the big Transit is 235/65x16", which is only a 28" tall tire. Going smaller, I don't think you are gonna get adequate load capacity. I believe the stock tires are load range E. Like the Sprinter and all the Euro van designs, tires are tiny to minimize wheel well intrusion into the interior.
There was a guy on this forum some time ago talking about lowering a Transit an inch or two to fit in downtown parking garages. I know the low roof Transit is 82.2" in passenger version and 83.6" high in cargo version, and my own garage door is 7 feet...so I could fit a passenger Transit in the garage but I don't think the Transit is where I'm gonna go after my E150. The low roof Transit is almost identical to the E van in exterior height but I haven't looked at interior headroom.
In theory, drop spindles would be ideal for the front but it's unlikely anyone makes them. In the rear, I would look at whether there are blocks between the axle and springs that could be removed. Or in the old days on cars with axles above the leafs, they used lowering blocks.
You would be reducing the suspension travel and belly clearance. You'd have to look at driveshaft angles if you lowered the rear axle.
I'm still looking at the 235/65 tire size and that is so small....they are using far larger tires on Explorers and Edges (not load rating E though).
I've missed you on the Transit Connect thread. I know there a little friction there, but the air cleared a bit and I would appreciate it if you would weigh in on a glitch that has been leaving me stuck in park.
