My 64 may have 2.5 total travel up front. It appears to be stock so I would be hard to imagine lowering it 2.5 without it being on the bump stops.
You should consider low profile tires. My truck has low profile tires on it in my avatar. They lowered the truck 1.5. Tires are less the the $900 for the springs. And easier to change. You will want to stay with narrow tires or the steering will get very hard in the parking lots.
I do not like lowered look so I went back with close to the stock size tires.
Literally sitting in Tulsa spring shop while my buddy sets up an alignment for his pump truck. Guy quoted me about 500 or so to De arch the front springs if I brought truck in and little less if I brought springs in (but then said I'd have put them back on and see if truck sits right and if have bring one side back in). I told him I've seen the springs for 500 new with the drop. He just said it's labor intensive
Its pretty easy for posters to throw out advice like have the springs de-arched or have a reverse eye put in.
Its another issue altogether finding a shop that can do that kind of work.
I know of none here. Theres probably shops in Atlanta, but that means leaving the truck on jack stands in the driveway for a couple days. Im not comfortable with that, I don't want a neighborhood kid playing around and getting hurt. We have a bunch of kids around here.
I didn't even think about it but a guy did a suspension swap and was giving away his old springs. I should have taken those and had the eyes reversed. If that opportunity comes around again I am going to jump on it.
Here is the way I did mine on my 64' using the stock springs. See post #12 lowering a staight axle ford f100? | The H.A.M.B. I now have 1.5"-2" between the bump stops with air shocks in the back. Costs almost nothing..
Any lower would require a drop axle and a C notch.
Jim, that looks great, I'm thinking about making this my weekend project. Did you use the same technique for the front and rear (flipping one of the leafs)? I love the look, nice and low, but not too crazy.
Also, what did you use to clamp the leafs back together ?
Thanks,
Seth
I removed the bottom leaf both front and rear and inverted the second leaf as shown in the forum post. Use a threaded rod and nuts in the center and run the spring pack together, using C clamps to hold the pack together. Remove the threaded rod and replace the spring pack center bolt. My back center bolts were old and tired so I purchased new ones at NAPA for a couple of bucks each.
it looks like you retained the bottom leaf and its unclear which leaf you inverted.
If the bottom leaf is leaf #1, please explain what you did.
I consider top leaf as #1, therefore I invert the next leaf down on the pack. Please see the #12 post in this thread lowering a staight axle ford f100? | The H.A.M.B. for diagrams and further explanation.
Thanks for the info! I'm gonna do mine tomorrow. Last question, what air shocks did you use, and did you just swap them with the old ones? Or did you make new mounts?
Thanks,
Seth
Swapped out the old for Monroe MA727 air shocks. Monroe had a nice rebate at the time I purchased the shocks so I was able to get new front shocks and rear air shocks for under $70 shipped. I did have to modify the mounting at the axle in order for the shock body to clear the frame. I used Grade 8 bolts and set it up as shown below.
Good luck with your springs Seth.
Reason: Added information
