Distributor Issue
Old Oct 19, 2015 | 10:40 AM
D.K's Avatar
D.K
Distributor Issue
After dealing with an intermittent no start issue that eventually lead to a complete no spark issue, I decided to replace the distributor on my 1991 F-150 with a 5.0 and E4OD. After weeks of sitting, it fired up, I timed it to 10* BTDC, and everything sounded great...then the problems started.
I began tightening down the distributor and it begins turning counter-clockwise. No biggie. I'll just hold it in place with 1 hand while I tighten the lock down bolt with the other. No matter how much pressure I held on the distributor, it still wanted to turn. I figured that maybe since the engine was still running, it may have been too much energy for the shaft so I turned it off. Tightened the distributor to where I couldn't turn it by hand, and went to fire the truck back up. The timing is WAY off. Even though I couldn't turn the distro by hand, cranking the motor still turned it counter-clockwise. I had to loosen the hold down bolt to re-time.
I tried tightening the hold down bolt even more, which lead to pulling 3 threads out of the block. Luckily I had a slightly longer bolt on hand and a few washers which I used to rig up a makeshift lock down clamp, but I can still turn the distributor by hand. Oddly enough, firing up the motor doesn't seem to make it move, but I can't say that I feel comfortable taking it out on the road like this.
The distributor is fully seated.
This is the replacement that I bought:
Amazon.com: Cardone (84-2880MA) Distributor: Automotive Amazon.com: Cardone (84-2880MA) Distributor: Automotive
I was using the factory hold down clamp and bolt.
Any ideas on what could have gone wrong?
Old Oct 19, 2015 | 11:03 AM
TeachNlive4ever's Avatar
TeachNlive4ever
Maybe the hold down plate is upside down?
Old Oct 19, 2015 | 11:16 AM
D.K's Avatar
D.K
I wish, but nope, at least I don't think so. I put it back on the same way I took it off...flat side facing up, beveled edge on the bottom and the bevel toward the distributor.
Old Oct 19, 2015 | 01:15 PM
TeachNlive4ever
It doesn't make sense. There is nothing that sould be rotating against the dizzy while tightening the "clamp".
Old Oct 19, 2015 | 04:16 PM
MR KROGOTH's Avatar
MR KROGOTH
I've heard of some distributor shafts and their gears being just a little too far downhole.
All I can recall, sadly.
I'd pull it out and compare to one at a parts store.
warren561
Sep 9, 2014 08:42 PM
bowling1
Aug 24, 2014 07:37 AM
AbandonedBronco
Jan 19, 2012 02:27 PM
garageinc2001
1983 - 2012 Ranger & B-Series
Jul 25, 2003 10:54 AM
bamagrasshopper4
Jun 3, 2002 11:52 AM
