lifted truck and a 5th wheel
P.S. That side mounted ladder may put you over the eight feet width allowed in most states. The builders don't think about that but a local State cop with a ******** will. You may want to measure it. Washing State has been know to issue citations for tow mirrors over 8 feet unless the rig had a wide load permit. The article I read noted that Indiana has also issued citations for wide tow mirrors over 8 feet.
Every Ford Super Duty currently made has a standard width of 104.9" - 8' 9", with standard mirrors.
From your pictures first I will give you credit for at least lifting the trailer the only "correct" way. That said you have created a more dangerous situation than the original because of the raised center of gravity, will it come back and bite you? Maybe, maybe not. One thing that would help is adding skirting to the bottom of the trailer, like the newer big rigs are running, that would at least help keep the wind from pushing you around when it gets under the trailer and tries to actually lift it. Not a perfect solution but it would help. Another consideration is that running the stiffest sidewall tires you can find will also help to keep everything steady. I have close to 5 million miles over the road doing heavy/wide and over height loads and I would NOT drive your rig!
Off topic but relevant to the work you did
I know this has been covered, and I know it's been done. I have a 04 f350 with a 4 inch lift in the rear and air bags and 6 inch springs in the front and 37's. I just bought a 5th wheel toy hauler and the axles have been flipped already, but with it hooked up to the truck it still sits like 10 inches nose high. So what I'm looking for is pictures of what you did to your trailers and how much you added, and how much is too much nose up.
Im currently trying to by your same trailer but it's out of state and it's an old guy who is no help what so ever in getting info out of. Just thought I'd try this route befor I make the drive and waste time.
Thanks in advance
Ty
2 questions how's the rig holding up since you raised it? Would it be possible given the frame structure of your trailer to install a receiver hitch to the rear to tandem tow?
Thanks in advance
Ty
Thanks in advance
Ty
Here is the Fed. Statement on this matter
LENGTH AND WIDTH EXCLUSIVE DEVICES
States must allow certain devices to extend beyond the 2.6 m (102-inch) width limit of CMVs on the NN and reasonable access routes. These include rear-view mirrors, turn signal lamps, handholds for cab entry/egress, splash and spray suppressant devices, and load-induced tire bulge. Also excluded are non-property carrying devices that do not extend more than 3 inches beyond each side of the vehicle.
Devices excluded from the measurement of the length include 1) those needed for loading or unloading that do not extend more than 24 inches beyond the rear of the vehicle; 2) resilient bumpers that do not extend more than 6 inches beyond the front or rear of the vehicles; 3) aerodynamic devices that do not extend more than 5 feet beyond the rear of the vehicle, provided they do not have the strength, rigidity, or mass to damage a vehicle or injure a passenger in a vehicle that strikes a trailer so equipped from the rear, and do not obscure tail lamps, turn signals, marker lamps, identification lamps, or any other required safety devices, such as hazardous materials placards or conspicuity markings; and 4) non-property carrying devices that do not extend more than 3 inches beyond the rear of the vehicle. All devices at the front of a semitrailer or trailer are excluded from the measurement of length. Tarping systems for open top trailers or semitrailers are excluded provided no part of the system extends more than 3 inches from the sides or back of the vehicle. For more details on these exclusions, see 23 CFR 658.16 and appendix D to 23 CFR 658.
So far it pulls nice, I have taken it on close to a dozen trips this year, with that being said I will say again that I don't tow over 60 or 65 mph, I have also always had the water tank full or close to, and I did put some good load range E truck/suv tires on it. As far as a receiver on the rear, the spare tire is mounted all the way to the back so you would have to modify it or do away with having it mounted there all together. The frame rails do extend all the way to the back of the trailer so it wouldn't be difficult to fabricate a hitch, as long as you are willing to modify/move the spare. Hope that helps
helps a ton thanks
sudsmcduff
Toy Hauler Towing; Fifth Wheel & Bumper Pull
24
02-27-2016 10:44 PM
Mussifto
Fifth Wheel & Gooseneck RV Towing
12-03-2012 09:28 PM
sandiegogreg
02-10-2005 02:38 PM
