Sponsored by: Real Truck
Not so cold start
Old Oct 13, 2015 | 06:24 PM
Showpanther's Avatar
Showpanther
Not so cold start
My 2000 F250 is not wanting to start already this year. I checked the relay and wasn't getting full voltage across so I replaced it and still hard to start. Before I start the glow plug replacement I thought I would through out the question, Is there anything else to check before I do the glow plugs?? I can key on and off 3 or 4 times and get it started but thats at 50 and 60 degree weather.
Thanks for any help.
Old Oct 14, 2015 | 12:32 PM
droldsmorland's Avatar
droldsmorland
Slow cranking or slow to fire? Two different problems. Slow to crank is batteries, cables, solenoid or starter. Test-clean-replace. Slow to fire can be clogged fuel filters or poor quality fuel or yes a bad glow plug or two. Test-clean-replace.
Engine spec(assumed diesel 7.3 ) and mileage on it?
Old Oct 14, 2015 | 06:43 PM
Showpanther
Slow to fire. And yes it's a 7.3 with 132000 miles. Will replace filter before tare down for glow plugs. Thanks
Old Oct 14, 2015 | 06:55 PM
Just Strokin's Avatar
Just Strokin
Autozone use to stock and sell the Motorcraft glow plugs for the 7.3.
Old Oct 15, 2015 | 08:57 AM
droldsmorland
FilterS right? Isnt there a primary and secondary filter on this rig? Also make sure the air intake filter isnt clogged. Still hard to fire report back...
Old Oct 15, 2015 | 09:37 AM
Squisher's Avatar
Squisher
Have you checked the new glow plug relay to ensure its working properly? Have you checked the harness or done the mod to ensure good connection at the UVCH? Then you would ohm the glow plugs before 'tearing into them'. Do you have a block heater? Does using it cure your issue or make no difference?
Next time it's hard to start try 'jumping' your glow plug relay with a screwdriver for like 20-30 seconds and see if it makes a difference.
Old Oct 15, 2015 | 03:51 PM
Topglock's Avatar
Topglock
Have you checked the cam position sensor?
99whiteford
Apr 6, 2018 11:41 PM
klle5
Dec 25, 2015 11:06 PM
Dev
Jan 10, 2010 07:11 PM
beersy50
17
Jul 12, 2008 10:24 PM
Vinford
18
Nov 4, 2007 09:49 AM
