C6 Transmission shift arm (help)!
Old Nov 25, 2012 | 02:09 PM
71BlueBoy's Avatar
71BlueBoy
So I am on my way to restoring my 71 highboy. I finished taking out a c6 with blown clutch packs. I located another c6 a old timer had under his bench for the past 22 years with 30k on it. I flushed the converter and cleaned up the new trans and checked all the torque on the inside under the cover. New gasket and re-torqued the pan bolts. I noticed the original c6 was ran without a kick down linkage. Perhaps that was the reason for the clutch pack going out.
1) I can not locate the kick down linkage on the World Wide Web.
2) The shift rod from the column to the tranny seems to short. I have tried all positions from P-1st. I am not sure if this is the result of the c6 I installed as it was hooked up to the old c6. ( or that's what they claimed). The truck had originally a 390 stick shift and they modified to install a 460 auto. Do they make a longer shift Rod for the C6?
I am so close to kicking it over and running it through it paces to check the new transmission and engine. But this shift problem has stopped my progress. I though of perhaps putting a slight bend in the rod to help it clear the firewall bump better and be in a position to attach it.
Old Nov 25, 2012 | 10:09 PM
71BlueBoy's Avatar
71BlueBoy
Anyone have any input to my issue with the shift linkage and kick down?
Old Nov 25, 2012 | 10:25 PM
Jon Hinds's Avatar
Jon Hinds
As far as the kickdown goes, I've personally never used one or known of anyone to use one. When the transmission needed to shift we'd just do it manually. That will probably save your transmission some wear and tear. As far as finding one I couldn't even find it on LMC truck. So you may have to hit up a salvage yard for that.
Bending rods to fit, in my experiences (which are few compared to some), has always turned out badly in the function end of things. I do NOT recommend bending a rod that will determine something as important as which gear you will be in. My truck (74 f250 460 C6) has a rod from the steering collumn which then connects to another rod that goes to the tranny arm. This is the sock set-up. Not sure of your set-up, but possibly if that's the case try a longer second rod?
Old Nov 25, 2012 | 11:49 PM
85e150's Avatar
85e150
Car and truck C6s have opposite shift arms. One up, one down, can't recall which is which.
As for the kickdown, it just isn't that complicated imo.
Lokar Hi-Tech Kickdown Kits KD-20C6HT - SummitRacing.com
Many to choose from here, including OEM parts it appears:
ford kickdown cable | eBay
Pics and serving suggestions:
http://raceabilene.com/kelly/hotrod/...ickdown500.jpg
Discussion of above, it's a C4 but it is similar:
Lokar Kickdown Questions - Ford Muscle Forums : Ford Muscle Cars Tech Forum
More:
https://www.ford-trucks.com/forums/1...crewed-up.html
https://www.ford-trucks.com/forums/9...n-linkage.html
Old Nov 26, 2012 | 06:08 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
I noticed the original c6 was ran without a kick down linkage. I can not locate the kick down linkage on the World Wide Web.
The C6 you removed was swapped in, it was not there originally.
You are not going to be able to find Ford parts that are correct, because 1973 was the first year that FoMoCo offered F100/250 4WD's & Bronco's with A/T.
All previous 4WD's were only available with M/T's.
Old Nov 26, 2012 | 10:11 AM
jim collins's Avatar
jim collins
I have a couple i have been using for years,10 and 15, with out a kick down with no problem . Like as said above you can use a cable in the rods place.__
Old Nov 27, 2012 | 09:16 AM
tpdaniels's Avatar
tpdaniels
Deleted Text, Did not apply to a 460 with a C-6
jesse howell
Apr 7, 2020 05:34 PM
jniolon
15
Sep 3, 2019 08:11 AM
dreamofford
Jan 19, 2018 01:21 PM
MAULMAUL
23
Aug 30, 2012 08:44 AM
Bookman
16
Sep 30, 2004 07:53 AM
