Brake question
Old Oct 11, 2015 | 04:16 PM
jbehuniak's Avatar
jbehuniak
Brake question
Good evening, I am trying to remove the rotor hub so I can replace the caliper on my 78 F250 4x4 351M I think its a D44 front end.
Right now i have the 4x4 hub out and the first nut off (the one with the 4 slots cut out of it) of the spindle. Behind it theres this other piece of hardware that has a bunch of holes in it. Question is how do I get that out so I can pull the wheel bearings and rotor hub?
Old Oct 11, 2015 | 05:02 PM
Pickupmanx2's Avatar
Pickupmanx2
Umm... that should be a "lock" washer, and behind it another nut that sets the pre-load on the bearings. That look different than mine, but try needle nose and see if you can grab it and pull it out.
Old Oct 11, 2015 | 05:26 PM
jbehuniak's Avatar
jbehuniak
That didnt work. On my 88 F250 it was a different nut all together and had all that in one assembly
Old Oct 11, 2015 | 06:03 PM
78fordguy's Avatar
78fordguy
Screw 2 of the bolts into it from the locking hubs. Then pull it out. After that Is another nut. Loosen the nut up a ways and pull the whole hub/rotor towards the nut to pop the wheel bearing off. Take nut off pull hub/rotor. Replace wheel bearing and pack with greese.
Old Oct 11, 2015 | 07:27 PM
77&79F250's Avatar
77&79F250
Moderator & parts slinger
X2 on just grab it with some fine tip needle nose or a curved pick on opposite sides (3 and 9 o'clock) and it should just come right out....There is a grove in the spindle that it might be stuck on? And there is a pin made into the back side of the lock washer that once you put the inner adjusting axle nut on a torque it properly that pin must go in a hole.
I think I remember it that way, hell I just did it a while back.
Old Oct 11, 2015 | 07:51 PM
78 PEB's Avatar
78 PEB
You remember correctly LOL Usually I just use an "L" shaped pick as you mentioned. Has always worked for me!
Old Oct 11, 2015 | 07:55 PM
77&79F250's Avatar
77&79F250
Thank you for the back up on the memory. I seem to remember a 2 lock washer/pin deal on some kind of something?
Now I am going to the shop to reread my manual.
Old Dec 24, 2015 | 10:38 AM
jbehuniak's Avatar
jbehuniak
The locking tab on the lock washer was driven into the threads for the axle nut. It eventually came out and the threads were not too messed up. New rotors, new F350 booster and master cylinder and front brake lines done too. Girlfriend helped bleed the brakes. Sorry for not closing out my own thread. As always appreciate the assistance and guidance.
Old Dec 24, 2015 | 10:53 AM
78 PEB's Avatar
78 PEB
Glad ya got it figured out!!!
Old Dec 24, 2015 | 08:20 PM
NW 150's Avatar
NW 150
You mentioned getting an F350 booster? I swapped to one in my 78 F250 4x4 a while back after reading about it, along with doing a disk brake conversion on the rear. My truck never had that much braking power. After driving my buddies 79 with the same setup but with the F250 booster, I put one back on mine and it locks up all 4 no problem. Just something to consider if your brakes don't feel that strong.
Happyreefer
64
Mar 1, 2015 04:47 PM
jdubbtx
20
Sep 29, 2007 06:04 AM
lowcan
Aug 10, 2007 09:44 AM
Trailcat
1978 - 1996 Big Bronco
Nov 6, 2005 01:32 AM
mwittman
1997 - 2003 F150
Feb 3, 2000 03:09 PM
