Engine cuts out for a split second when releasing throttle
Old Oct 15, 2015 | 07:00 PM
Kdawg89's Avatar
Kdawg89
Should exhaust back pressure be above 0 PSI at key on engine off?
Old Oct 15, 2015 | 07:09 PM
04badford's Avatar
04badford
It's not sensing exhaust pressure at koeo only low- idle, so unless the sensor is fault 0 koeo
Old Oct 15, 2015 | 07:15 PM
04badford's Avatar
04badford
I'm out of town with out my notes if memory serves me correct 14.0 koeo should follow MAP at or with in 5 psi of each other
Old Oct 16, 2015 | 11:42 AM
Kdawg89's Avatar
Kdawg89
So at KOEO EBP is 0, MAP is 12.5, Baro is 12. Do those all look normal?
Old Oct 16, 2015 | 11:45 AM
Kdawg89's Avatar
Kdawg89
Originally Posted by 04badford
With out my notes tonight but your EBP is off.
What do you see that seems off with the EBPS?
Old Oct 16, 2015 | 11:50 AM
WatsonR's Avatar
WatsonR
Depends;
If EBP is 0, your gauge could start at 0, but most are matched to MAP and BARO. BARO at sea level is 14.7-14.9 and for every 500' of elevation, about .5 psi less. If your BARO is 12.0, your at about 3000'... that about right?
If so, then they look good expect EBP, which needs the gauge checked if you entered it into a scan gauge. If you didn't program the gauge, it's bad. Try jiggling the wire to it?
Old Oct 16, 2015 | 11:54 AM
Kdawg89's Avatar
Kdawg89
Originally Posted by WatsonR
Depends;
The gauge is an Edge Insight CTS2. There are 2 options, my truck also has EBP 0 at KOEO so either my sensor is also bad or that is normal with that monitor.
I am at 4500 ft but my Baro and Map also read exactly the same.
Edit: Also worth noting is while I can't remember all of the numbers his EBP goes high than mine when revving in neutral and also while WOT, but we have different tunes and different intakes so I am not sure how much that would play into it.
Old Oct 16, 2015 | 12:41 PM
WatsonR's Avatar
WatsonR
EBP sensors are cheap.
EBP/MAP/BARO are the same KOEO normally. Truck running gets MAP/EBP up and BARO the same as KOEO. I think MAP+Boost=ebp. I don't get much EBP in park, but on the road can get 40+ easily on hard throttle.
Old Oct 16, 2015 | 02:32 PM
Kdawg89's Avatar
Kdawg89
I found this in another thread, "The technical reference changed for comparison from absolute to relative for the later years, but depending on the scan tool or monitor, both PIDs are selectable".
Based on that I think this truck and the PID I am reading is for comparison so it is saying EBP is 0 PSI different than MAP or Baro, not sure which.
davetelling
Modular V10 (6.8l)
May 2, 2019 02:22 PM
1998Ranger25L153CID
1983 - 2012 Ranger & B-Series
Jun 16, 2017 09:08 PM
northwindone
Modular V10 (6.8l)
Jun 9, 2015 12:27 PM
salamandagator
Modular V10 (6.8l)
31
Dec 31, 2009 08:00 PM
Dialtone
1997 - 2003 F150
Apr 14, 2006 07:36 PM
