E4OD over heating
Old Oct 9, 2015 | 05:45 PM
Trent Hatcher's Avatar
Trent Hatcher
E4OD over heating
I have a 96 f-250 with the 7.3l with 110k miles. I installed a new water pump recently and when the vehicle is Idleing the transmission temp rises slowly and as soon as I start moving the temperate slowly returns back to its normal temps. any suggestions on what would cause this?
Old Oct 10, 2015 | 12:22 AM
Toplait's Avatar
Toplait
Air flow through the Radiator cooling the oil down possibly...
If your trans is overheating may want to put another cooler on it. Also, check Line pressure. Check fluid level. Don't overfill it.
I'm not a expert on transmissions.
Mark might chime in here later on once he gets on...
Old Oct 10, 2015 | 05:46 AM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
Did it do this before the new water pump?
Old Oct 10, 2015 | 12:25 PM
Trent Hatcher
No it never did this before the water pump went bad. When it went bad (impeller shaft barrings and seals) is when I first noticed the higher than usual transmission temp as I was driving home so I could work on it. Then after replacing the pump the engine temp stays where it use to be, but the transmission temps still act up. For a basis no load going down the road or sitting before the new water pump the temps always stayed at 140-150. Now Idleing with the new water pump the highest I've seen the temps get to is 195. And cruising it can slowly go back down.
Old Oct 10, 2015 | 02:48 PM
Mark Kovalsky
You need to run a flow test on the trans.
Warm up the trans to about 150F. Remove the cooler line where it attaches to the rear of the trans. Get two buckets.
With the removed line pointing into one of the buckets have someone start the engine. Leave it idling in park. Once the flow is steady move the line to the second bucket for exactly 15 seconds, then back to the first bucket, and turn the engine off.
If fluid sprayed out of the rear of the trans it fails the test. If there is less than a quart in the second bucket it fails.
If it fails it means the cooler lines or coolers themselves are restricted. You would need to find and fix the problem.
Old Oct 14, 2015 | 06:08 PM
Trent Hatcher
I was finally able to do the transmission test and it ran through almost two quarts in 15 seconds. So I believe it passed.
Old Oct 14, 2015 | 08:15 PM
FORDF250HDXLT's Avatar
FORDF250HDXLT
i would much rather have 195F trans temps than i would 140F trans temps.*
"According to Ron Sessions, author of the Turbo Hydra-Matic 350 Handbook (HP Books), the ideal operating temperature for transmission fluid is between 175 and 225 degrees Fahrenheit."
your transmission is now running at a more optimal operating temp.
one of the more widely misconceptions about the auto transmissions is; the cooler the better.it's just not true.just like your engine,there is an ideal operating temp.
therefore,your thread title is incorrect.it should read: E4OD running at optimal temperature.
* temp reading @ the test port.
Royson12
16
May 31, 2014 07:19 AM
Benaghetto
1983 - 2012 Ranger & B-Series
Mar 30, 2007 04:01 PM
Ed the outdoorman
Sep 24, 2005 11:42 AM
bigfry
Apr 22, 2005 03:38 AM
200000+F150
May 18, 2003 12:03 AM
