Tailgate Latch Help
Old Oct 4, 2015 | 11:28 AM
kjephoto's Avatar
kjephoto
Tailgate Latch Help
Trying to fix the tailgate on my 78.
Right now the handle has full range of motion up and down. But it doesnt look like it's engaging with anything, it's just kind of moving on it's on.
The part i pointed out here in this picture doesn't rotate at all (431C88), which i'm assuming it should?? Could be rust.
I took out the three bolts holding the latch assembly in the bed and was about to kind of twist the whole assembly by hand and engage the rods. I couldn't do it enough to get the tailgate to drop but i could hear the springs compressing/decompressing.
Old Oct 4, 2015 | 12:31 PM
brian1080's Avatar
brian1080
Take the assembly out and give it a good degreasing/wire brush job. I've had several that were sticky, not too hard to get loose again. Even if you can't, a replacement is easy to swap.
Old Oct 5, 2015 | 02:42 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Here's a pic of the entire mechanism. Make sure the nylon clips (431C56) are attached to the link rods (431A78) and the handle assy (43400).
Old Dec 12, 2015 | 03:45 PM
MV10's Avatar
MV10
Any tips about how to get the tailgate open when the handle and rod are in place and moving, but don't appear to be releasing the latch? I can hear everything moving and I can look up inside and see the rod move. I can't tell if the latch is moving but it looks like somebody in the past tried to jimmy it, so I guess it has been a problem for awhile...
Old Dec 12, 2015 | 08:51 PM
77&79F250's Avatar
77&79F250
Moderator & parts slinger
Take two #2 flat tip screwdrivers and when some one is pulling up on the tailgate handle have 2 other folks pop the latches from inside the bed. See the red arrows? It should take just a bit of pressure.
Ck the main hinge piece to have bent tabs...
Old Dec 12, 2015 | 08:52 PM
Blue and White's Avatar
Blue and White
I'd give the sliding bolts on the edges of the tailgate a good shot of penetrating lube or WD40 first. Then try again.
It may be necessary to remove the handle mechanism. Make sure rods for both sides are accounted for... and a good idea to attach a light wire around each rod in case it drops to make it easier to retrieve. If necessary pull on the rods with pliers to release the tailgatge.
Once open and apart, clean everything up and inspect. Wire brush, solvent, emery cloth ect. Clean again and if everything is intact, lube. I used white lithium spray grease. The nylon clips or rod retainers are important for correct function. Replacements are available in the help section of the AP store in kit form... 2 kits were needed to do my tailgate.
Old Dec 13, 2015 | 06:44 AM
MV10's Avatar
MV10
Ah, ok, one rod is missing. From the diagram I thought there was only one rod to the right, but in mine I only have a rod to the left. That would do it... Thanks!
Old Dec 13, 2015 | 07:06 AM
77&79F250's Avatar
77&79F250
I bet the R/H rod came out the middle handle part and the outer end is still connected and it just fell down inside the t/g. Fishing time.
Old Dec 13, 2015 | 05:13 PM
Roger Carter's Avatar
Roger Carter
I have had the plastic clips, 431C56 in the diagram, break and allow the rods to come out of the handle assembly. If I remember correctly I could reach into the tailgate, past the handle assembly, and get the dropped rods.
Make sure everything is cleaned and well lubed when you put it back together,
A year ago the clips were still available and my local Ford dealer and weren't too expensive.
Hope this helps.
Old Dec 22, 2015 | 07:26 AM
MV10's Avatar
MV10
Turns out the handle mechanism was bent out of shape and the latches weren't fully disengaging, but I did have both rods, I just wasn't looking far up enough in there to see the right-hand side (hard to see because of the damage to the mechanism). One of the nylon clips was missing and the other was kind of chewed up, so I'm hoping that's the reason they weren't moving correctly.
beautyandthebeast
Dec 1, 2015 08:00 PM
LawBoy01
Jun 26, 2014 06:22 PM
Blindbatts
Nov 22, 2008 10:33 AM
1973FordF100
Oct 28, 2008 02:05 PM
Stanstruck
Apr 5, 2004 01:10 AM
